Question about Whirlpool Dryers
I have an estate TGDS740JQ gas dryer. It has two problems that are probably linked. The first is the dryer will run for hours sometimes and sometimes it shuts off like it should. I snaked the vent and replaced the timer but that didn't solve the problem. The second (new problem I think) is the heat doesn't always kick in? I checked the thermal fuse and that was closed. After checking the fuse and thermostats the heat then worked???????? Any ideas? Thanks.
  • Whirlpool Master
  • 8,220 Answers
The coils on the gas valve assembly get IFFY with age. I have an estate TGDS740JQ gas dryer.  It has two - themobilian_671.jpg
I have a service manual and more HERE
Posted on Jan 04, 2011
Testimonial: "will try thank you"
Dryer tumbles, but does not heat
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 20, 2011 | Estate TGDS740JQ Gas Dryer
Dryer not heating up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Estate TGDS740JQ Gas Dryer
Gas dryer does not ignite
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 10, 2010 | Estate TGDS740JQ Gas Dryer
HOW DO I LIGHT THE PILOT LIGHT
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 15, 2010 | Estate TGDS740JQ Gas Dryer
Gas dryer will light but will shut off and will not relight
The problem is the dryer coils are failiing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Aug 05, 2010 | Estate TGDS740JQ Gas Dryer
Gas dryer does heat up
The problem is the ignitor...
Check out this tip that I wrote about that problem...
heatman101
Apr 09, 2010 | Estate TGDS740JQ Gas Dryer
Dryer runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Mar 13, 2010 | Estate TGDS740JQ Gas Dryer
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
How do i change an estate TGDS740JQ gas dryer to propane
they have gas to LP conversion kits online. just google for it. Its not a tough job if you have mechanical experience, otherwise call a pro.
Nov 06, 2009 | Estate TGDS740JQ Gas Dryer
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
