The light that indicates 'CLEAN PUMP' came on... for a minute.....i can't find the manual... i gave the draw where powder goes a rinse and the light went off......question being-.....how do i CLEAN the PUMP? thanks for your time
  • Washing Mach... Master
  • 8,220 Answers
How do I fix this problem? When I start the dishwasher, it runs for a minute or two, then stops and the "Clean" light comes on. So far, I have replaced the control panel, the power module, and the Hal
If you pull up on the float and the water burps a couple of times and does nothing else, then your drain pump is bad. It is doing a rinse of the inside before it adds the detergent, if the drain motor is bad it will simply let this small amount of water in the bottom and adjust the indicator to clean. I have had this same issue with mine. One clog and the motor goes kaput.
Jul 27, 2014 | Bosch Dishwashers
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
Sep 23, 2013 | Washing Machines
Delonghi coffeemaker dcf6214t clean light won't stop flashing after descaling how do I reset it to default ettings?
Hi, Cathy,
Most of the above solutions do not address your DCF6214T drip coffee maker. I had this problem, also. The manual is useless on this subject. The support telephone did help somewhat, but, also referred me to the website where I found the same useless manual.
Try this:
1. fill carafe to the 14 cup mark with warm water. (aprox 2L)
2. mix in 2 tablespoons of citric acid (a white powder available at Indian supermarkets) mix to dissolve completely.
3. pour acid into the coffee maker. and mount carafe in the machine and close the door.
4. with the on/off light off, and the clean indicator flashing press the clean button. The machine will fill the carafe over the next 3 hours, giving the acid lots of time to dissolve deposits.
5. After the on/off light goes off discard the dirty acid, rinse and refill the carafe with clean water. Fill the machine with water then mount the empty carafe in the machine.
6. With the on/off light off and the clean indicator still on, again press the clean button. This time the carafe will fill in about 6 minutes, as this is just a rinse to remove the acid.
7. Repeat 5 and 6 two more times. (I did it 3 more times, for a total of 4, but I believe 3 should work, according to the manual and the telephone support line.) (That is one acid clean followed by 3 rinses, all without pressing the on/off button.) (After all this, the darn clean indicator will still be on and the on/off light will be off.)
8. Now, make a pot of coffee and breathe a sigh of relief as you notice the clean indicator finally, turn off.
I hope this helps supliment a total failure of the manual to explain how to perform the clean operation.
Oct 20, 2012 | DeLonghi dc Coffee Makers & Espresso...
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Softer is not leaving the drawer into the drum
If you machine is like ours was I think you'll find the water channels within the draw are blocked with sludge, remove the powder draw from the machine then disassemble it completely making sure you remove the centre insert then rinse/flush it out completly with hot water.
Before replacing the powder draw get a wire bag tie and poke it through the holes in the top of the machine that feed water into the powder draw to ensure these are also clear of blockages.
Dec 14, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
