Question about Refrigerators
Aeg santo fridge water leaking into door seal and runs onto floor when opening the door, also the door has incredible suction after closing and is difficult to open soon after closing
  • gcatuk Mar 21, 2009
    aeg santo fridge freezer leaks and water comes out at side
Had the same problem. I'd already tried waggling the drain rod from inside the fridge but to no avail. I pulled out the fridge and pulled off the 'top hat' end on the very end of the corrugated drain pipe. Inside was pretty gunky.
Just clean it thoroughly especially around the little rubber mushroom and the problem goes away. Simples
Posted on Aug 22, 2011
I have an AEG Santo 72348 ka fridge that is supposed to be self defrosting. Mine regularly freezes up inside. Any help ?
Usually this is a symptom of a faulty door seal or a very frequently opened fridge they extra moisture load from the environmental air.
Feb 18, 2013 | AEG Refrigerators
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
Why is or fridge leaking water out the bottom. Bottom mount fridge, checked the water try in the back, no cracks, no leaking, Twice in four days days it leaks water on the floor. No problems cooling,...
I've seen this occur when the refrigerator door is getting closed fully Either a food item is preventing complete closure, (though it may look closed) or a seal is failing. Check the seals by pulling a dollar bill out from in between the seals. If it doesn't catch make sure the seals around the doors are ingood shape and clean.You can also use a heat gun to warm -up the seal and get to expand so you get a good suction
Oct 15, 2010 | Kenmore Refrigerators
Constant build up of water at the bottom of the fridge - what can I do to solve the problem
Check if the pipe or hose that supply water for the ice maker is not leaking. Look in the back of the fridge at the bottom part to see if frost is building up on the pipe then melting and putting water on the floor. Build up of frost on the line indicates low on freon or something is wrong with the fridge. It will still get cold but the frost will melt and put water on the floor.
Jun 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
My aeg santo 70168 has a puddle of water at the bottom every few days.
if the water is inside check the drain on the back of the fridge if it is on the floor make sure the drain hose is in the drsin pan
Dec 07, 2009 | AEG Santo U 86000i Compact Refrigerator
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Aeg santo 1688 fridge power/light flashes when door open
Check if the bulb is loose in its socket, you may be able to twist it to tighten it, turn off the power first though.
Oct 13, 2008 | AEG Refrigerators
My AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor. Is this a common problem and can it be fixed? - for example by replacing the opening rubber...
Peace BeeSuit,
Happy to be of assistance,
You asked:
Your, AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor.
- for example by replacing the opening rubber seal?
Yes I believe that replacing the rubber seal is usually the answer.
How old is the unit? And is the washer working well other wise?
Is it draining and not smelling like mold in side?
Some times in an old machine the pump does not completely dran out and it could smell like moldy water! Then if it's aged. I would consider not fixing both of these to problems in a washer 10 years or older not to put good money in to bad!
But if the leak is the only problem, go for the seal!
Happy to of assisted and made a different s in your life!
Bless you,
Huuum
Please give me a good rating for my sound advice before you sigan off.
Thank You
huuum
Sep 12, 2008 | AEG Washing Machines
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
654 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
