Question about Hammering
I am wiring a 240 volt, 30 amp 2 pole receptacle for a construction heater. I am using 3 wire romex. i hooked up the ground, red and black wire and capped to white nuetral wire. i hooked up the red and black and ground in the 100 amp subpanel and also capped the white in the panel end. when i put it on i get the light on the heater but nothing else. i thought it was the heater but bought a new one so i must have something wired wrong but not sure. does it matter what side the red and black are on, i did switch them around but the same issue. confused.
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The only thing that would make sense is you have the two lines somehow on the same bus bar in the box or a supply issue either to the sub-panel or in it. When you power up the circuit are you getting 120 or 240 across the red and black wire? Double check the 240 in the sub panel if you only get 120. If you are getting 240 all the way to the heater then you are missing something within the heater or its instructions.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 04, 2011
Testimonial: "sometimes even the little things can hold you up, glad there are thoses willing to share information and help a newbie out. Awesome!"
  • xc700coyote Jan 04, 2011
    Great checked a few things like you said. had 240 coming in an was reading 0 at the plug across the red and black 120 at the black and ground. i did have it on the same bus bar. dumb mistake but totally makes sense now.
    Thanx much :)
  • John Prohaska
    John Prohaska Jan 04, 2011
    Glad it's fixed...please take a moment to rate the answer. We work on a volunteer basis and keeping our ratings up helps make it worth while :)
How to wire recepticle for pump 240v, 2-speed fan motor 240v, purge pump 240v
If you are asking how to wire up a receptacle to run a 240 volt pump, you need to have a box on the roof first of all. You will need a 20 amp double pole breaker for this. You will need to pull 2- hot wires from the breaker box, 1- neutral, and a bare ground wire. Size of wire would be # 12 THHN stranded wire. A total of 4 wires. This would be to code. Or, buy enough Romex wire, #12 with ground wire and red, black, and white in side, tie into the breaker that way. Red and black will be your hot wires to pump, if it has no neutral you can use both the white and bare to ground, very easy to do.I hope this is what you wanted to know.
Shastalaker7
Apr 23, 2011 | Mastercool 67680 Evaporative Cooler Air...
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
May 03, 2009 | QMark FBE15002 electric baseboard heater...
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Cadet wall mount and thermostat
your wiring is all wrong. for a 240 heater a 20/20 tandem breaker will not work with a 240 heater. you need a 20 amp two pole breaker. the two wires at the heater need to be connected to the line. you probably have two black wires at the heater. one connects to the white romex which should be taped black, and the other romex black connects to the other black wire. at the panel one white goes to one side of the breaker and the black to the other. the bare ground goes to the neutral bar.
Oct 27, 2007 | Cadet Manufacturing 67507 Heater
Hammering Logo
431 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
