Question about Garden
Its getting gas and spark but won't start - Garden
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
It sounds it could be flooded.plull the spark plug, pulg tha plug and let the engine block evap over night. Clean and adjust the gap on the plug;(40").
Posted on Jan 04, 2011
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Won't start can't even get it to fire got spark getting gas ,don't know.
Check the compression! It has to be around 120 and no less then 100 to fire off. If it is ok, Have your carb checked out. It should fire off with some spray.
Feb 10, 2013 | Poulan Garden
2003 kia Sedona won't. start
If this is a sudden occurrence and nothing suspicious happened prior, you most likely lost either gas or spark to the engine. You need to check for both.
Do you hear the fuel pump in the gas tank buzz on for a couple of seconds when you turn the ignition key to ON? Unless the fuel pump turns on and puts gas under high pressure at the fuel injectors, the engine cylinders won't get gas to start. Correct fuel pressure is crucial to know if you have a fuel pump (or fuel filter) problem. If the pressure is correct, it is probably not a fuel problem but a spark problem, although there are less common instances where a fuel injector circuit may malfunction.
The ignition system not producing spark at the spark plugs is the other common problem of no starts. Buy a cheap spark tester at a parts store, plug it into one of your spark plug wires, then crank the engine over and watch for a strong blue spark. You might need a helper to do this. If you see a consistent spark, the ignition system is probably good, although you should probably check more than just one plug wire-sometimes one bad ignition coil in a coil pack will cause no starting. Good luck.
Jan 28, 2012 | 2003 Kia Sedona
Turns over won't start getting gas up top to fuel injectors, but won't start
GIVE IT A SHOT OF STARTING FLUID IN INTAKE IF IT RUNS FOR A MINUTE THE CONTROLER FOR INJECTIORS HAS PROBLEMS IF NOT CHECK FOR SPARK AT SPARK PLUGS THIS WILL TELL YOU REALLY WHAT SYSTEM YOUR HAVEING PROBLEMS WITH. USALLY IF THERES FUEL AT INJECTORS ITS A SPARK PROBLEM GOOD LUCK
Aug 20, 2011 | Dodge Neon Cars & Trucks
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
