Question about Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish
My fan is starting to squeel like it needs oil. Is there a p[lace to oil it? If so please tell me where to find the oil inlet. I have looked, haven't taken the fan down, just looked at it from a ladder.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
fans have sealed bearings, these types oiling wont work
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
Hunterfan com
try finding the maual
here is a good p[lace to start
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Nov 28, 2013 | Dryers
1999 Oldsmobile Alero 3.4 ltr v6 Problem is in the Heater/AC Fan Blower. Blew fuses. Took out the fan Blower and found frozen water at the base of the motor and didn't allow the fan to turn. Removed...
There is a technical Service Bulletin that covers the exact thing you are describing. I would post a copy of the bulletin here, but it is copyrighted material, so I'll just give you the details....
Open the hood and remove the wiper arm assemblies. Remove the air inlet screen panel. Replace the foam seal that seals the inlet screen at the base of the windshield. (I have actually just sealed them with clear silicone before) When you reinstall the inlet screen, make sure that the lower lip on the winshield lace goes over the top of it. If it is on top of the window lace, it will make your problem worse, not better.
Feb 23, 2011 | Oldsmobile Alero Cars & Trucks
Where is the fan belt located on a suzuki swift?
It dosent have a fan belt it should be an electric fan mounted on your radiator if its making a squeeling belt noise its probly the altinator belt located on the righthand side of the engine bay.
Jul 10, 2010 | 1990 Suzuki Swift
I have a 2001 Sonata. I have a squeeling pulley.
It sounds like you have a worn or streched belt making the sqeeling noise. Whenever you turn on a
device in the car that draws a fair amount of voltage
ie. a/c or headlights it will cause increased drag on
the alternator and if you have a loose/worn or glazed
belt, it can slip around the pully making the squeel.
To adjust the alt-a/c belt loosen the mounting bolts
on the tensioner, then use the adjuster bolt behind
the tensioner pully to loosen and tighten the belt.
Be sure to check the belt for cracks bald spots etc.
While the belt is loose spin the pullys to make sure
they all spin freely. Also I would replace the belt just
to be sure. Hope this helps
Jul 04, 2010 | 2001 Hyundai Sonata
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
Haven reall problems starting bike when warm espeacially valvw clearance on inlet is 0.10 and exhaust 1.2 are they to tight
If they where to tight it would not start when cold, and get easier when warm. I would look at overheating check oil/coolant levels.
Nov 19, 2009 | 2008 KTM 250 SX-F
So, i start my 95 nissan pathfinder up, and one of the belts starts squeeling, (fan belt?) and after the squeeling I can hear a slightly metalic "buzzing" comming from (what I think is an engine pulley)
Get a Can of Fan Belt Dressing at your Auto Parts Store and spray this on your Belt. It will Make the Belt Quiet ehough that we can Narrow down the Other Problem. Let me Know! Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 27, 2009 | 1995 Nissan Pathfinder
94 nissan maxima se, Squeeling loud when car is started.
I can't tell exactly what it is since I cannot hear it, but in most cases it's a belt. Check that first, or have a friend help you - one of you can start the car and the other one can look under a hood to search for the squeeling part.
Sep 16, 2008 | 1994 Nissan Maxima
Sqeeling motor
If the blade on your Lake Breeze fan is held on with an allen screw, it's probably loose. I bought one at a thrift store lately and it had this problem.
Aug 22, 2008 | Lake Breeze SG16B3 Stand (Pedestal) Fan
Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish Logo
56 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
