My RCA HDTV is not working. When turned on, the green power light is lit on for 3-4 seconds, goes and comes on again for 6-7 seconds. Following this, it is gone. There is no picture or sound on the TV. The picture of my TV had convergence issue, which I fixed under directions of an expert. It worked for several months. After the recent problem was encountered, I re-did what I did for fixing the convergence issue (thinking that some soldering was not done properly), but the conditions were not changed. The model number is HD56W66.
  • 4 more comments
  • din_riaz Jan 05, 2011
    I know a very little about electronics. However, I successfully fixed the convergence problem following the directions on how to do that. I first time opened the TV's back cover, correctly located the fuses and soldering that was deteriorated. What tools to use and what parts to buy; every thing was told by the Guru.
    Can I get a complete step by step instruction to find and fix the ptoblem.
  • din_riaz Jan 06, 2011
    It never turns red. After second liting green, the green power light turns off. The screen remains black during this whole time.
  • din_riaz Jan 07, 2011
    It sounds you are taking me in right direction. Since I am ignorant in the field of electronics, I don't know how and where can I find the parts you told me. Previously somebody gave me so perfect directions that I was able to locate the specified parts without any problem and fix the blurred screen problem. Could you please further extend your help.
    One more thing. This problem arose few months after I did desoldering and desoldering of the flyback. Is it possible I short circuited the board? I have just re-done all that soldering, but no improvement.
  • din_riaz Jan 10, 2011
    I don't see any capacitor with cracked, leaky or swollen caps. Could you please tell me more specifically with the specs and location of the possible faulty parts, and what to check on those parts.
    Sorry about that. Actually I was unable to find any bad capacitor. Could you please tell me specifically the location, part number and/or specs of the capacitors that I should check.
  • din_riaz Jan 13, 2011
    I perhaps replied to you that I was unable to find the capacitors you are referring to. Could you please tell me specifically with part number, specs and location.
  • 4,889 Answers
After the green light goes off, does it turn red and blink? Or does the LED at the front just go off?
Posted on Jan 05, 2011
  • 3 more comments
  • eagle338
    eagle338 Jan 06, 2011
    Its a confirmed case of protection fault alright, but since the LED does not blink at all it is most likely to be the power supply or the deflection board. The first thing you should look for would be for faulty electrolytic caps(with swollen , cracked, leakycaps) which can cause this issue by overloading a particular voltage line , there by triggering the protect fault. Let me know how it goes.
  • eagle338
    eagle338 Jan 07, 2011
    The capacitors I am referring to are cylindrical objects with an X-mark at the top. The power supply is the one into which the power cord plugs into and the deflection board is the one with the flyback. These are the boards on which you should look for the faulty capacitors.
  • eagle338
    eagle338 Jan 10, 2011
    I got a mail alert but I cannot see your last response, can you please post it again?
  • eagle338
    Ok. If its not the caps , we are gonna have to go for component level testing. Can you get me the chassis number of the tv(its under the model number of the tv on the label at the back) so that I can see if I have a service manual for this model?
  • eagle338
    eagle338 Jan 13, 2011
    I got that reply. THats why I said, please get me the chassis number of the tv so that I can see if I have a service manual for this model so that we can try more comprehensive component level troubleshooting. PLease click the view more comments link at the bottom to see further comments.
  • 11,800 Answers
The blinking indicates that an excessive current is detected one of the output rails from the power source. When this happens the power source is put in protected mode first . If this doesn't work (since it starts blinking a second time) it's shut down for good. You must open the tv and test the power source: since it's a big current draw it means that a big consumer has failed so start checking with the high tensions - the ones that power the horizontal deflection module and the video finals. You must determine the location of the failure: in the power source (the rectifier diodes and the filtering capacitors - the most likely cause of problems in a tv this old) or in the other boards - the power transistor for the horizontal deflection is the first one you should look at.
Posted on Jan 04, 2011
  • Azrael SRL Jan 05, 2011
    This isn't a simple fix, you must first diagnose the problem and identify the failed parts. There is no step by step for that. If you don't have at least basic knowledge on how a tv components work and what is their role in there you simply cannot fix it yourself. Sorry, time for a repairman.
I have a 52" RCA
The deflection board needs replacement. You need the PSB260 deflection board available from www.tvrepairworld.com
May 17, 2011 | RCA R52WM24 52" HDTV Projection Television
I have a RCA HD52W59 HDTV that won't cut on
Capacitors in power supply if it trys to come on with a green light then goes off and attempts to try again maybe 3 times total before it is off completely
Oct 13, 2009 | RCA HD52W59 HDTV Projection Television
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
http://servicemanuals.vstore.ca/
Feb 07, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have an RCA R52WH74 That when you attempt to turn it on the green light comes on for about 6 seconds then turn off if you hold the power button in it flashes 1-9 over and over what could be the problem
Replace 3 capacitors cp150 2200uf 16v If it is puffed up on top it is bad ,need to replace 2 more caps cp120 cp114 220uf 35v they are green with gold writing on them.
Nov 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
POWER WONT STAY ON
You have bad Capacitors cp150 2200uf 16v, cp111 330uf 35v cp114 220uf 35v this is common with these sets they are on your deflection board green with gold writing 2200uf etc. Look at capacitor cp150 if it has a bubble look on top it is bad so replace all 3 caps.
Oct 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WH74
the 3 blinks is definately meaning the flyback is defective. You need to replace the flyback its number 259296 you can get a replacement flyback at the following link with free installation instructions with step by step pictures of the repair. Heres the link.
Sep 30, 2008 | RCA P52937 52" Rear Projection Television
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
