Question about Memorex Ultra Traveldrive - 160GB USB Hard Drive
I back everything up but when i put it on another computer the file is not there. It only appears on the computer I saved it from
    Novelist:
    Scholar:
  • 111 Answers
It may have prepared to put the file there, but not actually written it. Like burning a CD... you might right click on the file and see if it gives you the option to write it, or close it.
You might also make sure you check your system tray, and see if there's an icon for connected devices (like thumb drives and USB accessories). You may need to right-click that and "stop" the device so that's it's safe to remove.
That's a pretty reliable drive and not too many troubles in general.
Are you using similar versions of Windows (or other OS)? It's possible it's writing in different formats and not visible on that score. Check the drive size (used and available) and see if the storage is correct but you just can't see the files.
Good luck!!
8^)
Posted on Jan 04, 2011
Reset a Inspiron 15
Backup important files and data
  1. Click Start, and then click Control Panel.
  2. In the Control Panel window, click System and Maintenance, and then click Back Up and Restore Center.
  3. Under Back up files or your entire computer, click Back up files.If the User Account Control window appears, and you are prompted for an administrator password or a confirmation, type your password, or click Continue.
  4. On the Where do you want to save your backup? page, choose the location in which to save the backup. To do this, click either On a hard disk, CD, or DVD or On a network, and then specify the location. If you select a hard disk, be sure to save the backup to an external drive such as a USB key or USB hard drive.
  5. Click Next.
  6. On the Which file types do you want to backup? page, click to select the check boxes next to the types of files that you want to back up, and then click Next.
  7. On the How often do you want to create a backup? page, leave the defaults as they are and click Save settings and start backup, to back up the files to the specified location. Backup will save the files in the background and may take several minutes to complete. If you specified a removable drive, Backup may prompt you to enter an additional blank disc if more than one is necessary to hold all your files. Be sure to label your discs thoroughly (such as "My Files Disc 1" etc.) so you can quickly restore them later.
    Once the Backup Complete message appears, you are ready to proceed with the next step.
Remove non-essential peripherals
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
An external peripheral is a device that connects to a port on the front, side or back of the computer, like a printer or memory key.
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one.
Restore the computer's software to original condition.
  1. Turn on the computer.
  2. As the computer starts, press < F8 > on the keyboard until the Advanced Boot Options menu appears on the screen. You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  3. Press the < Down Arrow > on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press < Enter >.
  4. Specify the language settings that you want, and then click Next.
  5. Log in as a user who has administrative credentials, and then click OK.
  6. Click Dell Factory Image Restore.
  7. In the Dell Factory Image Restore window, click Next.
  8. Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
  9. Click Next. The computer is restored to the default factory configuration.
  10. When the restore operation is completed, click Finish to restart the computer. The software is now installed as it was when the computer was first received.
Restore your personal files and data from backups
  2. In the Control Panel window, click System and Maintenance, and then click Back Up and Restore Center .
  3. Under Restore files or your entire computer, click Advanced Restore.
  4. On the What do you want to restore? page, click Files from a backup made on a different computer and click Next.
  5. Locate the backup you created earlier by browsing to it now. If you saved the backup to CD(s) or DVD, insert that disc now. Once the backup is located and selected, click Next.
  6. On the Select the files and folders to restore page, click Restore everything in this backup then click Next. Backup will restore the files to your computer. If you are restoring from a removable drive and used more than one blank disc, Backup will prompt you to enter the next disc in the set as necessary. Depending on the number of files and their sizes, this process may take several minutes.
Aug 23, 2015 | Computers & Internet
How to reset laptop
Knowledge Base
Restoring Your Computer´s Software to the Factory Settings for Windows Vista
Table of Contents:
  1. Backup important files & data.
  2. Remove non-essential peripherals.
  3. Restore the computer's software to original condition.
  4. Restore your personal files and data from backups.
  5. Download and install driver updates
This article provides information on restoring your computer´s software to the factory settings.
Dell has designed two new backup and restore programs.
Dell Inspiron, Studio, and XPS computers use DataSafe Local Backup 2.0 as the PC Restore/Factory Image Restore option as of April 22, 2009.
Dell OptiPlex, Latitude, Vostro, and Precision computers use Dell Backup and Recovery Manager as the PC Restore/Factory Image Restore option as of May 26, 2009.
  5. Click Next.
    For additional resources to help resolve issues not covered under Dell's limited hardware warranty, refer to Dell Knowledge Base article, Search for Additional Solutions .
Back to Top
  • Scanner
  • Printer
Back to Top
Back to Top
Back to Top
Once your operating system has been restored, visit the Dell Support website to download and install the latest drivers and firmware for your computer.
Sep 30, 2012 | Dell Latitude D420
I did a system recovery, during which it asked me if i wanted to save files and pictures..I said yes but now I can not find my old files
do another system recovery going back to an earlier date when you did the last recovery. If you find one then go back to it. If you get everything back, do a BACKUP of everything u want to save on an external HD. Finally you can do another recovery to bring your computer to were u are today and do a restore from your backup set to put back anything you're missing. good luck
Aug 04, 2011 | Computers & Internet
IF OUR CD DRIVE WHICH IS MY COMPUTER FILE IS GONE(IN MY COMPUTER IT HAS DISAPPEARED) THEM FROM WHERE WILL I DOWNLOAD NEW LG SUPER MULTI DRIVE INSTALLER?
Hi Kundan,
Its not that you need to install anything to make your CD or DVD drive reappear in the My Computer list of Drives. The answer lies elsewhere.
CAUTION / WARNING!: Go ahead and follow these steps only if you are confident of doing it. Else get it done from a hardware engineer.
1. Switch OFF your PC's power supply and unplug it from the AC mains outlet.
2. Open the cover of your PC & look for the data cable connecting your CD/DVD drive to the motherboard.
3. Remove the data cable from the motherboard end and put it back in the same manner.
4. Do the same on the CD/DVD Drive's end as well.
5. Also remove and put in again the power socket of the CD/DVD Drive.
6. put back the PC's cover.
7. Plug in your PC to the AC Mains and switch ON the power.
8. Start you PC and let it boot normally.
8a. Go into your CMOS setup (by either pressing the Del key or the F2 key) whatever the case
might be. Here, look for auto detection of the drives attached to the motherboard's SATA or
IDE ports (again whatever your case may be) If it shows your drives i.e. Hard drive and the
CD/DVD drive then it should appear when you restart your PC. Press F10 and say Y in the
Save & Exit Setup window. This will save your CMOS settings and reboot.
9. Once everything has started up and you see your desktop with its icons & everything, go in My Computer and see again for the CD/DVD drive. It must appear.
If it still doesn't appear then try this:
WARNING!
Nov 05, 2010 | Computers & Internet
My Zen mp3 player wont work.
If you can try to open the files on your computer by search files option, then opne them and save the lot to a secured folder. Then completely format the device, erasing all the date stored. reset teh device once again and now put back antivirus scanned files back from your PC saved folder. Please check all the files for any error befroe you reload. I hope this will help you out. Good day
Jul 05, 2010 | Creative Labs Zen Digital Media Player
My PC could not save a file in my Flash drive but only if i place the file in a folder then it will be saved.What could be the problem.Please help!!!
i would take everything on the flash drive and put it on computer format the flash drive and then put it back on could be problem with flash drive unless this is the only computer thats doing it
Jun 04, 2009 | Dell Dimension 1100 PC Desktop
Pc does not save data or files when i restart
Adware are common files that are coming in and out to you windows and sometime the firewalls is blocking your install files you can add this in exemption so it will not block the file,doing this click panel control,click firewall windows,click excemption and add the file you want so it will appear and install in your windows.
Mar 05, 2009 | Dell Dimension 2400 PC Desktop
Audio Devices
Kinldy download the updated drivers from the following webiste.
http://tinyurl.com/ysy86c
Download
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install instructions
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:DELLDRIVERSR12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:DELLDRIVERSR12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Thanks
proton
Oct 27, 2008 | Dell Dimension 2400 PC Desktop
PSP Games
You most likely need to format the memory stick with the PSP. What may have happened is once you've upgraded, the PSP re-rooted itself into the memory stick. So it's looking for a folder that doesn't exist. (But that's just what I think...) I've had this problem also. After you format it with the PSP, it should work fine. As for your game files, they should still be saved on the memory stick. Search all your files with your computer then save them to your computer so they don't get formatted. After the format, put the files back onto the memory stick where they belong and everything should work fine! Please ask if you have any questions!
Jan 02, 2008 | Sony PlayStation Portable (PSP) Console
Theme upload on memory card problem
to see those themes file and install them first you have to insatll any file manager like fileman or fexplorer, download and insatll any from these file manager software on your mobile, then you can able to see different folders and files of your mobile. among them you can find themes which you have saved. click on them they get installed.
Aug 25, 2007 | Nokia 7610
Memorex Ultra Traveldrive - 160GB USB Hard Drive Logo
29 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
