I tuned the tv on and after it scane the channels the tv came i have atleast 60 channels now i only have 29... channel 30 says audio only 30 thru 60 no picture, and then the channels say like 30.20
  • 50 Answers
Is your televison set to cable mode or broadcast mode?
Who is your cable provider?
Comcast recently, in my market disabled the ability to receive the new digital format unless you use their converter box.
Posted on Jan 04, 2011
Tv only picks up channel 30 when auto scaned
Tuner fault. Check and repalce it. Contact any service technician. Gopakumar Gopalan Google
Feb 28, 2014 | Sceptre Televison & Video
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
I have an older emerson tv that I can not get to pick up channels above 36. It is pluged directly into my cable outlet. When I hook up another tv it will get around 90 channels. Is there a setting I can...
I doubt that there is a setting built or designed in your tv, older tv tuning systemslike yours were designed for what was back then available as far as channel capability(cable ready sets)what ypu can do is get a cable converter and get the channels thru the box or if you have a vcr hooked up you can always select channels thru te vcr tuner if the tuning system in the vcr is newer. thanks!
Jan 05, 2010 | Televison & Video
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
No sound on just one channel
Do you have another TV in house that works with this channel correctly? Do you have a VCR (or VCR/DVD combo) that you can use to tune to this channel? I'm wondering if your tuner is going bad on this one channel. Do you have SAP (Second Audio Program) turned on? You may want to turn it on and then check channel for sound. I'm assuming that you're getting your cable feed thru coax and not composite (red & white audio). If you are using composite, try switching the red & white inputs to see if sound comes in. It's possible that cable company is only outputting audio on left or right channel and something is wrong either with one of your TV's speakers or with the cable company's output.
Mar 06, 2008 | Orion STV2763 27" TV
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
