I have Scheu Universal 250-VC/250-S, SPC-250VC/SPC-250S, 250,000 BTU Construction Heater that lights great and puts out the heat, but the air flow running past the pilot light "bends" the flame away from the thermostat and it cools down and shut off the gas flow. What can I adjust to keep the pilot light from "bending" away from the thermostat?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
Just a thought, but...is the compressor in any way blocked by weeds, etal.
bon chance
Ashley
Posted on Jan 04, 2011
  • PJ_mrfixit Feb 08, 2011
    The pilot orifice is blocked. Remove it and utilize a solvent like brake cleaner to remove the blocking material. Had the same problem. Works perfectly. Not enough volume of gas to keep the flame on the thermocouple.
I have a Scheu 250,000 BTU Propane heater, It will work for approx 15 minutes and then shut off
This heater is very similar to a heater available in the UK, the "Bullfinch 1400", also known as a "Bin heater" because of it's resemblance to the shape of a dust bin or trash can. This heater has a flame failure valve, also known as a safety valve or relay valve, but it may be a coincidence that the heater shuts off at exactly the same period of time every-time, but it would seem to indicate a fault with either the thermocouple or the flame failure valve, or possibly the over heat thermostat if there is one fitted to this heater. The Bullfinch 1400 for example does not have a overheat stat.
Jan 07, 2012 | Scheu Heating & Cooling
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Nov 21, 2009 | All-Pro Propane Garage Shop Heaters - All...
I have a Scheu Conviction Heater. Model 80vc/spc80-vc. I would like to know if you use it in Colorado Mountains does it make a differents in the altitudes on running it. Thanks A Bunch
You should not have a problem using these units in the mountains. The only units that you may have problems using in the mountians (over 4,500 ft) is vent-free units that have the ODS pilots. I hope this helps...
Mar 21, 2009 | Scheu Heating & Cooling
I currently have a Scheu Universal 250, 250-A all pro spc-250, SPC 250-A 250,000 BTU constructtion heater that I can't get working. I've connected to a propane tank w/ regulator and can't get it to fire. I...
I have had the same problem on a smaller unit (30,000 BTU). I remove the cover, take the thermocouple out of the burner area, and clean it until bright with either scotch brite or very fine emery cloth. The deposit on the outside prevents it from tranfering the heat to the hot end of the thermocouple and in turn to the sensor. I usuall do this once a year. The cleaning hasn't worked for me recently but the unit is 12 years old now and I will look for something else to fix.
Dec 23, 2008 | Heating & Cooling
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Dec 03, 2008 | All-Pro Forced Air Kerosene Space Heater...
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
222 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
