Question about Hoover Washing Machines
Where is the geasrbox located on machine where can
Where is the geasrbox located on machine where can i find a assembly layout
  • 153 Answers
Location is on underside of machine
Posted on Jan 04, 2011
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
What is fuse box layout in and out on this unidentified vehicle?
Without any kind of identification, it's hard to answer this kind of question. Usually fuse boxes are located either driver's side of dash, or underneath....also fuse boxes are located under hood on driver's side. As for layout inside of fuse box itself, the cover usually gives you a layout of fuses.
Sep 09, 2015 | Cars & Trucks
Keys need remaping
Check to make sure you have the location settings correct in your computer as different locations around the world use different keyboard layouts. I.E. US keyboard layout is different the Great Britain layout.
Feb 26, 2014 | Toshiba Equium A110-233 A110-252 A110-276...
Gearbox problem
The problem is a bent shift fork. The fork slides a gear left and right to engage other gears.
Google " Gilera VX 125 manual " This should help you out big time!
Please rate this solution to your problem. Thanks!
Mar 21, 2009 | Gilera Runner VX 125 Motorcycles
Burned resistor, need value for replacement
I re-drew the schematics from the PCB-layout and did some backward engineering to determine the resistor value. The machine is now again in excellent working order.
Jan 20, 2009 | Sewing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
