Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Paper Feeder Jams
The document feeder on my XD125F is beginning to misfeed regularly. It fails to pick up pages, and occasionally (though infrequently) picks up two or more sheets. Where can I purchase a rebuild kit for the document feeder? This is a very nice machine, and I would hate to replace it because of worn rollers.
  • ki7ay Jul 09, 2008
    The link you cited does not work. I get "bad request" when I attempt to access it. Could you check your typing and reenter please?
    President:
  • 2,072 Answers
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Posted on Jul 09, 2008
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
I have a Canon Image Runner 3230 which we also use to scan PDF files into our snap drive. When scanning a large job build, if the machine jams, the documents already scanned in the job build are lost. Is...
Hi mail. Let me tell you a workaround for this problem.First of all I understand every aspect of your question and problems as the document feeder for the ir 3220 is about the biggest piece of **** I've ever seen and I have been working on copiers since 1988.And when you use the "Universal "SEND" " function I also realize that for example if you have scanned a 500 page document and it jams at 499 you have to start all over again.That because the copier has established communication with the server directly during the "send" process and when an error {document paper jam} occurs, for whatever reason the error cannot be reconciled on the fly. BUT!!!!! :-) If you scan the same document(s) to the "Mailbox" function the copier can and will allow you to recover from such a mishap as the process you are conducting is all happening "on board" the device so if a jam or misfeed occurs in the document feeder during the scanning process the copier will tell you to put the stack of originals back in the feeder with page 1 on top.Then the copier will begin to feed the originals quickly merely to count the pages till it finds the the one it jammed on.Once it counts to the original it failed on it will resume the scanning process.THEN...... no matter how many failures have occurred during the process, once you are done the "SEND" function will appear as an option.At this point you will be viewing the "batches " of documents in the display because if it is a large document you will not have been able to put the entire bulk in the feeder at once.Now highlite all of the"files/batches" and hit EDIT. Under edit will be the "merge" option. Select merge and all the batches you have highlighted will be merged together into one big document.NOW selest SEND and designate the location you wish to send it to.Since the document in its entirety resides correctly in a "mailbox/hardrive" storage area it can be sent with no fear.I have many customers with this same difficulty and this has been a lifsaver. hope this help,and have a better day! :-)
Feb 10, 2010 | Canon imageRUNNER C3200 Copier
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
