Question about Bosch 24 in. SGS43C02 Classixx Built-in Dishwasher
How do you "undo" the aqua stop?
Waste water hoses of washing machine and dishwasher are both running into the same waste water pipe under the sink. When washing machine runs water is being "pushed" into the dishwasher. This sets off the aqua stop.
Any Idea of how to switch off the aqua stop without calling an engineer??
Thanks a lot for your help.
Audi693
  • Anonymous Mar 15, 2014
    Found this aqua colored thick rubber band like a gasket at the end of wash and do not know where it belongs.
  • 770 Answers
Create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
How do i fix the connecting hose from washing machine to pipe under the sink that drains water away
Here in Thailand the washing machines have no drain pump and the drain hose must be run at floor level.
If you live in the UK or USA for example, the machine will most likely have a pumped discharge and the hose is normally hooked into a standpipe behind the machine
Check out You Tube for further information regarding under sink plumbing
How do install freestanding dishwasher or washing machine
Dec 29, 2017 | Washing Machines
The drain hose vibrates while dishwasher is running unless sink faucet is on, which stops the vibration.
Try throttling back (reducing the water flow) the valve that feeds the machine. With the sink tap/faucet running the pressure into the dishwasher is reduced. Is the feed pipe kinked or blocked in some way as there might be a sensor in the machine that doesn't like it when water is "jetted" in under pressure. It would act like putting your thumb over the end of a hose when washing a car.
Jul 21, 2015 | Dishwashers
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Water from the sink fills up the dish washer
I had a similar problem with a washing machine, until I replumbed my waste pipes. My Washing Machine waste pipe was attached to the down pipe just under the sink bowl. I found that the U bend trap was too high and the water level in the U-bend was at the same level as the Washing machine waste pipe was attached. So we has syphoning back into the washing machine. I moved the U bend trap down by 3 inches 7 cm, so now the water leaves the washing machine falls the 3 inches to the water level of the U bend. We now have no more syphoning back into the washing machine.
Jul 05, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Water leaking from underneath pipe connector to the dishwasher
Check the following:
* Loose or mis-positioned hose clamp at the drain spur connection
* Rotted or brittle hose
* Split hose
* Cracked joint at the drain spur connection or split drain spur fitting
Apr 27, 2009 | General Electric Dishwasher Timer
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Drum filling up with water
There are 2 possible problems here. 1. If your waste pipe is connect under the sink and uses the sinks waste as a drain it could be that water from the sink (or dishwasher if also fitted) is entering the machine via the waste. This can be cured by ensuring that the washing machine waste hose is hooked up higher than the connection under the sink. 2. It could be that the washing machine inlet valve need replacing. After time, or if bits of dirt enter them they can let water seep through. This is easily identified by turning off the water supply where the hoses are connected to. If the machine fills up then you know it is entering via the waste hose - if it doesn't then you know its one of the valves. If it is a valve they are available from us at www.ransomspares.co.uk
Feb 28, 2007 | Indesit W 123 Front Load Washer
Bosch 24 in. SGS43C02 Classixx Built-in Dishwasher Logo
2,025 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
