I need to know how to install a memory upgrade
    Novelist:
    Scholar:
  • 96 Answers
Turn off the computer, open the case, then find the memory sticks that are already installed. there will be clips on either side of the slot. move those gently away from each other and they will open up slightly. Then slide the stick into the slot and push down. If it doesn't go in, check to make sure it isn't in backwards, there is a slot in the stick that will only allow it to be inserted the correct way. once you have it creectly alligned, press down until the clips snap into place.
This is how to physically put more memory in, but make sure that what you've bought is compatible, and matches or replaces the sticks already in place.
Posted on Jul 09, 2008
I need to add memory but don't know what I need. I don't want to get the wrong memory upgrade but I had it cleaned out and upgraded, its way to slow to run windows xp with only 256 RAM
First, you need to know the max your computer can hold. Then, simply go and buy them from best buy. I think they will also install it for you. If not, then check out this guide.http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
Jan 10, 2010 | Toshiba Tecra 8100 Notebook
How to install memory upgrades on GATEWAY GT 5042B PC
CLICK HERE. to get all the information you need about your computer.
Memory:-
  • Installed: 512 MB DDR2 533 MHz (PC4200) SDRAM
  • Expandable to: 4 GB (4 DDR2 slots)
  • If you want to know how do i install it? CLICK HERE.
    please rate my solution very high, if this infornmation is helpful.
    Sep 23, 2009 | Generic Memory Computers & Internet
    Need to upgrade memory have bought memory cards and want to install them how do i do it
    Hi..
    To upgrade your memory besure that you will know what is the socket of your memory slot. Before you buy a memory look at your memory socket first so that the memory you buy is totally fix to the socket. Open you unit and look for the memory stick inside. If you dont have a little experience on how to upgrade it's better that you will go to the computer shop to ugrade your unit. So that the upgrading is successful, if you can do it with your own it is ok because it is not expensive.
    Regards
    ICmanServer
    Aug 01, 2009 | Acer Aspire 3680 Notebook
    Gateway 500x upgrade ram installation.
    hi! there if your addibg a memory card check your memory speed if match to other memory card that are installed already,they should have same speed e.g DDR PC228 or SDR PC333 so check this out before installing.But if you replace the older one upgrading,switch off your computer open cover,there is slot there for your memory card bedide your processor,at both end there a lockway,unlock your memory card and pull it out all if you have several one,then insert on one slot if that is one memory card at 2gb lock it on both end.then swich on your computer check this out on your computer properties if there is change.how to do this left click my computer,click properties.regards
    Mar 27, 2009 | Gateway Computers & Internet
    Verify memory upgrade in a Inspiron 1200
    Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
    Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
    Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Nov 27, 2008 | Dell Inspiron 1200 Notebook
    Upgrade memory on Toshiba laptop
    You'll find a small panel on the back that you can unscrew to add more memory/ram (or change the current card). Here's an illustrated guide: http://www.fonerbooks.com/laptop_2.htm
    Nov 02, 2008 | Toshiba Satellite A135-S4527 Notebook
    Installing memory upgrade
    No.
    Once you install the memory into the slot the BIOS will update the memory configuration during the bootup proccess.
    You can check to see if your new memory has been fully recognised by double clicking "System" in control panel.
    If you check the amount of memory in System before the install and compare it afterwards you will know for sure if the memory has registered correctly.
    Aug 03, 2008 | Dell Dimension 3000 PC Desktop
    Installing Memory
    Hi
    Yes, you can replace/upgrate the memory module under the keyboard.
    Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
    Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
    Read "Preparing to Work Inside the Computer" before committing to the above procedure.
    Let me know how you get on.
    Mike
    May 24, 2008 | Dell Inspiron 2650 Notebook
    MEMORY UPGRADE
    Nowadays, you'll have to scrap what you have and insert new 512M sticks, if you can find those in your design parameters...accordianman
    Feb 17, 2008 | Memory Upgrades my14576 External Drive
    Computers & Internet Logo
    57 people viewed this question
    David Payne
    David Payne
