Question about Insignia NS-LTDVD19-09 LCD TV
I am using the HDMI connection and I don't get any sound on certain (but not all), non-HD channels
SOURCE: No Non-Hd sound
Okay,
I was having the same problem as well as the others. I had initally hooked my t.v. up with a HDMI cable, which made the picture look great, but resulted in no audio on non-HD channels. After repeated calls to Comcast, BestBuy, and the Geek Squad, I finally was directed to call insignia which I did. The woman there told that HDMI would only support HD channels, and not Non-HD channels. She told me to try componet cables (red, white, yellow, green, and blue) from my Comcast box and the TV. I went to Comcast & they gave me the cables for free. I took them home, hooked them up, and the TV now works great with audio on all channels.
The back of the TV has it listed as "input," and that is the menu option to choose to view channels on this input.
Hope this helps
Posted on Nov 30, 2008
  • 108 Answers
SOURCE: No sound on NON HD channels
Check menu on tv and see if the audio input has any other settings. May have different options for sound processing.
Posted on Jan 06, 2009
SOURCE: No sound on Insignia 27"
http://www.fixya.com/support/t1314756-no_non_hd_sound
This looks similar.
Posted on Jan 11, 2009
SOURCE: insignia LCDTV dvr combo - no sound on non HD stations
The link below echoes that it is a tv issue, not an issue with the box.
Just returned from Bestbuy/Geek Squad and they can fix this problem but only by sending it back to Insignia.
I've been searching for a simple Firmware download to use via the USB port (like my bluray) but nothing found yet.
Geek squad was nice and they knew of the issue but I'll stick with the Component cables, as it's only a 19" TV.
If you find the update, please pass it along!
Thanks!
Posted on Feb 21, 2009
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
I connected my HDMI cable to my television and have comcast for my provider. I get the HD Channels beautifully but when I go to a regular non HD channel, I get no sound at all, only the picture. How am...
You will need to used a red and white cable that will connect to the (audio out) on the comcast box and then to your (in audio) on your tv.
Thanks
wbigtodd
Jan 22, 2011 | Insignia Televison & Video
Pixilization on non hd channels with hdmi cable connected to HDPVR receive. HD channels come in crystal clear, non hd channels are all bitmapped and horrible
Your TV is not at fault, it is showing you the difference between HD and non HD channels. HD TV's work great with HD scorces but don't usually look that great with standard definition, Also the non-HD channels are more likely to be heavily compressed which makes them look bad too.
Nov 03, 2009 | LG 42LG30 42 in. LCD HDTV
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
Vizio 22 inch HDTV--Loss of volume on non-HD channels only
Good evening! Go into your audio section of the Menu and make sure that SAP is off.....let me know how you did.
Apr 21, 2009 | Televison & Video
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
Insignia NS-LTDVD19-09 LCD TV Logo
23 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
