Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
The engine will run but chain does not move. what could be the broblem
  • 43,501 Answers
Right inside of where the bolts are that hold the bar on and the chain tensioner is... there is a centrifugal clutch that engages the chain when the engine revs up...that clutch has gone bad and is not transferring the power from the saw to the chain...
Of that is assuming that the chain is on the sprocket and not sitting off to the side of the sprocket...
heatman101
Posted on Jan 04, 2011
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
Motor runs well but chain wont move,l it only 3 months old what next?
Make sure that you can move the chain by hand and that it is being properly oiled. Remove the bar and chain after releasing the chain brake. Clean the side of the engine where the bar fits to, then start the engine--oil should ooze out of the port. Wash out the interior of the clutch with spray carburetor cleaner to clean away excess oil accumulation. Clean the drive end of the bar small oil passages that run from the large holes out to the chain groove on each edge. If oil oozed out during the run test, reassemble everything making sure the chain teeth cut toward you on the bottom run. Adjust the chain up to the bar, but not so tight that you can't move the chain by hand. Tighten the cover fasteners and recheck the chain tension. Start the engine and run the bar tip near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Dec 12, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I bought a used McCulloch 4016. The engine can rev up nicely, but it cannot cut through 2 inch piece of wood. It does not stall, the chain just stops moving, and the engine seems to slow down as if it...
A dull chain can certainly cause loss of cutting ability and generate a lot of heat in the chain. The clutch may be full of chain oil and is slipping. Remove the bar and chain, then wash out the clutch internals with spray carburetor cleaner and let dry out. Clean the oil passages in the drive end of the bar including the two small passages that go out from the large holes to the chain groove an each side. Clean the entire chain groove. Start the engine with the bar and chain off of the saw--you should see oil ooze out of the small port in the engine case where the bar fits to. Reassemble the bar and chain after everything is cleaned--tighten the chain until the lower run just pulls up to the bar, but you can still run the chain by hand. Make sure the chain teeth are properly file sharpened and the teeth cut toward you on the bottom run. When running, the engine should 4-stroke at speed unloaded, but immediately 2-stroke when cutting. Hold the bar tip near some cardboard while running the engine at speed for several moments--it should throw off a thin line of oil on to the cardboard. Hope this helps!
Jun 13, 2010 | Garden
I have a poulan woodshark p 3314wsa it starts and runs, but chain doesn't turn
Does the chainsaw seem to rev up without any resistance, or does it bog down as you push the throttle? If it revs up quickly, then it sounds like the clutch plates may be frozen - usually due to rust. If it boggs down, then the chain and/or clutch housing are frozen or stuck somewhere.
The chain drive uses a centrifugal dry friction clutch with two weighted plates that are spring loaded. The springs keep the plates disengaged from the clutch housing to allow the engine to spin freely at an idle (or slip when the chain slows down due to the blade binding).
When you press the throttle, the engine revs up and the higher RPMs create centrifugal force causing the clutch plates to push outward - fighting against the springs, and begin creating friction on the inside of the clutch housing. If rust prevents the clutch plates from moving out to cause the necessary friction, the clutch housing (and drive gear which is permanently affixed to the housing) won't spin and the chain won't move.
With the engine OFF and cool...first take a thick towel or rag and place it over the chain with the engine switch in the OFF position. Try to move the chain in the normal rotation (top forward, bottom backward) to see if the chain moves freely or if it is stuck in position. If it does move, then take off the chain cover and then get a can of PB Blaster and spray the clutch plates and springs. Give it an hour or so and then take a rag and wipe off the excess and reassemble and try it. The excess PB Blaster will burn off with the heat of the clutch and the rust will no longer be a problem.
If the chain won't move, then somewhere along the drive the chain or clutch housing are stuck. Look for a bend or kink in the bar where the chain rides.
May 29, 2010 | Garden
Chain jumps off guide
Remove the bar and chain. Lay the chain out on a bench or table--inspect it for sideways bent or broken links. Check the chain drive teeth for damage as well as the sprocket drive teeth. Inspect the bar chain groove for damage or sideways bending, also the tip sprocket for free turning. Start the engine after cleaning the bar mounting area on the side of the engine, it should ooze out oil after running for a short time. Clean the bar drive-end oil passages which run out to the chain groove. Clean the entire chain groove. If all checks ok, re-assemble the bar and chain, but leave the mounting fasteners finger tight. Tighten the chain until it pulls up to the bar bottom, but not so tight that you can't move the chain by hand. Tighten the bar fasteners firmly and recheck the chain tension. Start the engine and run the bar tip near some cardboard at speed for a few moments--it should throw off a thin line of oil. Hope this helps!
May 12, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Just got MCC4516F chainsaw.Used it for 30 mins. Stopped working. Chain brake does not engage or release. Chain does not move. Motor runs but will not engage to make blade move. Seems like chain brake...
You have obviously jammed or broken the chain on the inside of the motor. Take it to be repaired, or try reparing yourself by opening up the engine casing yourself.
Nov 19, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I can start up the chainsaw, but chain doesn't spin
Is the chain brake on? Pull the lever your knuckles are against toward you to unlock the anti-kickback brake.
Jun 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Mccullough chain saw pm610 chain slips -- maybe clutch issue
have you greased your clutch bearing ever.some times they get dirty and tighten up after running a while.pull your clutch off and clean and grease bearing with a little alex grease,and I mean just a few drops.not meant to have a lot of it,too much will burn the crank shaft and you will have more problems then you started with
Jan 01, 2009 | Garden
Saw is running, but chain is not moving
If you rev the engine and the chain does not spin, either the chain is jammed, or is adjusted to tightly on the bar, or the centrifugal clutch is malfunctioning. With the engine off and leather gloves on, see if the chain will move on the bar, you should be able to move the chain 4 or 5 inches. If you can spin it, the clutch is probably bad. If its stuck, take the housing off over the clutch and make sure the chain is seated on the sprocket and not jammed to the side. Inspect the chain on the bar, there should some slight play in the chain tension. Look for any links that dont flex. This happens to be cause I overtighten the chain to the bar.
Dec 22, 2008 | Homelite Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
64 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
