Question about Ovens
My oven was working fine yesterday and now the bar underneath in the bottom oven glows but no fire starts. I don't have any $ to pay for this to get repaired and I definitely can't afford to replace a double oven. My husband says he can replace parts if he knows what the problem is. Can anyone help? Frigidaire model# FGB24T3ASA double oven
  • Barrett Palumbo
    Barrett Palumbo Jan 04, 2011
    before i help, does your husband have a manometer and gas leak detector, these will be need to make repairs..
  • Ovens Master
  • 8,220 Answers
The ignitor should be real bright (hard to look at), if it is dim orange it is weak and a weak ignitor won't open the safety valve. This video explains how it works: Silicone carbide ignition
Posted on Jan 04, 2011
Testimonial: "You were a huge help. Thanks for your time."
Bottom oven does not start
I HAD THIS SAME PROBLEM THIS WEEK. MY REPAIRMAN TOLD ME THE GLOW BAR IGNITOR ARE BAD TO GO BAD. EVEN IF IT STILL GLOWS IT PROBABLY ISN'T PUTTING OUT ENOUGH GLOW TO OPEN UP THE SAFETY GAS VALVE. I THOUGHT MY PILOT LIGHT MIGHT BE OUT, BUT THEY DON'T EVEN HAVE ONE FOR THE OVEN/BROILER IN THE BOTTOM OF STOVE, BUT IT DID HAVE ONE FOR THE TOP BURNERS.
YOU CAN WATCH SOME YOU TUBE VIDEOS OF HOW TO FIX THE GLOW BAR IGNITOR FOR THE OVEN AND LEARN MORE--HOPE THIS HELPS..
Jan 23, 2015 | Ovens
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
Gas oven not firing.ignitor not glowing.burners work fine.oven has been used in past for kitchen heat in winter months non low temp
dont use the oven for comfort heating not a good idea,, u prob need to replace that glow bar or ignitot part, gonna need ur brand and model number u ccould look up schematic at sears good luck
Jan 28, 2010 | Hotpoint Ovens
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
Glow plug comes on and smell gas but no fire
That is a bad gas valve. Need too change it out. The glow bar is working but the valve is not opening.
Sep 02, 2009 | Tappan 30IN ELEC IGNa Oven
Oven not working
hey, turn the oven on and see if you see an orange glow at the bottom. this would be your glow coil. exactly like the broil. if you do, take an amp probe and check the amp draw to it. it should be over 2.9 amps. if no glow or low amps replace and start baking. enjoy
May 17, 2009 | GE JGRP17 Gas Single Oven
Glow bar??
it sounds to me like you are on the right tract yes you can change this item pretty easily after you remove the covers it just plugs in just follow your wires and do not touch the new glow bar with bare hands use a clean rubber glove like doctors wear to hold it (the oils on your hand will cause it to go bad faster.although rule of thumb is to replace the glow bar and gas valve at the same time you may get lucky and fix the problem with just the glow bar.after you replace the bar (if it does not work the problem would be the gas valve>NOT RECOMMENDED TO DO IF YOU HAVE NO MECHANICAL KNOWLEDGE
LET ME KNOW HOW IT TURNS OUT FOR YA.YOU CAN EMAIL ME DIRECT AT FIXITRIGHT1@YAHOO.COM I HOPE THIS HELPS YA
BILL
Jan 06, 2009 | Ovens
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Ovens Logo
109 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
