Question about Fisher and Paykel Fisher & Paykel Washer
Washing machine won't fill, it stops and starts about 3 times then it beeps and light 3,5,7&8 are on,how can I fix it?
  • cjoya78 Jan 04, 2011
    thanks so much,my hubby did exactly what you said and it worked!! now we know what to do if it ever happens again
  • 2,382 Answers
Hi, check the reed switch under the lid,and the out of balance switch under the lower board they may be rusty so the machine thinks the lid is open causing this fault
3,5,7,8 code lights indicate an "out of balance fault" Fault 43 according to F&P, It is not a hard job to fix, you will need a new/second hand micro-switch and possibly 2 female spade electrical connectors,a pair of crimping pliers, a star/philips head screwdriver,and a flat blade screwdriver.
Firstly you need to electrically isolate the machine, ie. pull the plug from the power outlet. Then remove the 2 screws at the back of the control panel, lift from the back and it unclips at the front, lay it on its face. We need to get access to the out of balance switch which it to the right of and under the electrionic control box. Remove the single screw holding the electonics box(black box) and move wires so as to allow the box to be lifted up just enough out of the way to access the switch. Use a flat blade srewdriver or strong fingers to unclip and remove the microswitch, replace the switch but inspect the spade terminals for corrosion, replace if corroded. There is a waterproof upgrade for this problem from your dealer. Or you can do what I did and get some spare switches from other electronic devices, they are quite common. The part number for the switches I used was 120727C.
Posted on Jan 04, 2011
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
Hi, my fisher and paykel 7.5kg top loader washing machine is not filling up with water when I start a load. It starts to fill then stops, then fills a little more, the stops completely. I am not too sure...
Hi just read your posting.When the machine stops completely does the machine beep.If it does beep then a series of lights will light up.These lights will be in a row of 8 lights.Starting from the left to right which lights are on when the machine beeps,Is it the 2nd and 7th or the 1st and 6th etc?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Washing Machines
Long wash & spin light come on with contiuous beeps, every second... tried turning power off then on etc Machine starts up, water fills & drains but the alarm coms up after time... Any ideas?
Hi just read your posting.From the information in your posting the lights that are lit when the machine beeps are,On the row of 8 lights starting from left to right ,the 1st and 8th.Is this correct?Please reply with additional information and I am sure I can help.Looking forward to your reply.
May 18, 2011 | Fisher and Paykel Washing Machines
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
When using the smart drive 051 the machine attempts to start filling (on a cold wash) then the water flow switches off after a few seconds and timing is inconsistent of the attempts to fill. After 3...
Hi just read your posting.Now when the machine beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which ones are lit.Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Aug 03, 2010 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel washing machine. Model MW512NZ. It has stopped working properly. The water is stopping and starting when the machine is filling and although the machine will pump out it will...
Hi just read your posting.Now the lights that are flashing will be in a row of 8 lights.Starting from the left to right which lights are lit,Is it the 2nd and 4th or the 3rd and 6th ---etc---?Please reply with the additional information and I can help you rectify this fault.Looking forward to your reply.
Aug 01, 2010 | Fisher and Paykel Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
344 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
