Question about Frigidaire GLTF2940E Front Load Washer
The washer works oke ,but it does notspin after the washcycle,nor the rinsecycle.shall I have to check some board,or something else?
  • 1 more comment
  • Ivan Kelly
    Ivan Kelly Jan 04, 2011
    I took out the lockswitch.canthis switch be tested before I buy another?
  • Ivan Kelly
    Macmarkus,yourhelp was super.You are a real Guru.Thanks you very much.Ooh,I almost forget to wish you a Hapy New Year,and keepup the good job.Next time I have a problem I will visit FixYa and ask for you.Have a nice day . Ivan Kelly .
  • Ivan Kelly
    The washer works perfectly.Thanks
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa.
Based on what you've described, and provided the unit is draining ( and I mean the drum is clear of water aside from the items being soaking wet )...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swaThe washer works oke ,but it does notspin after - 46e20c7.jpg from the old assembly to the new onThe washer works oke ,but it does notspin after - 95f0559.jpge in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Jan 04, 2011
  • Mark MacDonald
    Mark MacDonald Jan 04, 2011
    Hello again,
    The diagnosis of the switch is actually in the symptoms, since it is energized and the door does lock, the unit does drain, it is just the spin not working...indicates the switch IS at fault.
    This is the reason for my questions regarding the draining, and provided the door locks...since it is basically a multi-function switch. it is preventing the control from going into spin.
    Aside from pulling out the tech. sheet in the unit and going through many test which are not always accurate anyway, ( too much room for error in my opinion ) you're safe to order a switch and save your time...which is likely more valuable than the switch as well.
    Let me know if I can provide any further info and I'll certainly do what I can. Good luck.
    Regards,
    Macmarkus :)
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Fisher and Paykel Kelvinator Washingmachine All lights on n
too many clothes in the washer maybe
hows about a F&P manual?Gimme a dollar LOL!
Sep 13, 2009 | Fisher Washing Machines
Fault
the only thing you can do yourself is leave the set unplugged for over an hour, this will reset it to factory settings. If that does not do the trick it will need to serviced. Chances are if it is a rear projection set that the convergance board is dead. This would be more to fix than the tv is worth.
Jul 07, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
HE2-plus washer will not start. error, status light shows "F-24"
code F24
sorry but the following information is for TECHNITION SERVICE(only)
"Was this helpful?"
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Smelly clothes and machine!
Do you wash whites separately or with bleach? Sometimes changing up the loads to whites with bleach would kill the germs.
Jun 12, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Open Questions:
Frigidaire GLTF2940E Front Load Washer Logo
126 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
