Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
How to unlock a sandisk cruzer usb flash card 16 gb
  • Brian Girouard Jan 04, 2011
    Can you clarify what you mean by "unlocking". What exactly is happening when you insert the flash drive into the usb port? I need to know what you are seeing to properly instruct you on a solution.
    Thank You,
    Brian
    Master:
  • 389 Answers
If you cannot open your usb drive, you will need to open your drive management. Sometimes, drive letters that the usb drive looks for, usually F, G or H, are taken by other drives. You can change drive letters on other network drives to different letters, therefore, allowing the usb drive to access the letters it is looking for, and effectively, unlocking it. Below are directions on using the Disk management utility in windows:
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility. Also, drive '0' is usually your main hard drive.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Posted on Jan 04, 2011
How do I unlock my sandisk cruzer 8 Gb if I lost the password key for my pen drive ?
if you have lost the password, you could attempt using a password cracker, but there are no legitimate methods for recovering a lost USB password.
Oct 26, 2014 | SanDisk Electronics - Others
How do i remove write protection on a sandisk cruzer 16 gig usb device
Format it with your windows format tool then right click on it in the device control screen select "run as administrator"
Oct 07, 2014 | SanDisk Cruzer Edge Sdcz51-016G-B35 16 Gb...
How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
i have a 16 gb pendrive which is detected in my mac but not in any windows...............help me out here
May 10, 2009 | Electronics - Others
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
950 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
