Question about Cell Phones
What size screw driver do i need to take apart a my touch 4g
    Guru:
  • 91 Answers
A 2mm phillips head should work
Hope this helped
Posted on Jan 04, 2011
Touchpad doesnt register press half the time. sc200 uniden scanner
You can take it apart and see if the touch pad is a membrane with impregnated carbon pads on the back of a silicon sheet. If it is, you can use alcohol to clean the pads and board. When you take it apart, take pictures as you go and draw a diagram for screw locations and put the screws in the diagram so that they are not left out or wrong size. Good luck
Mar 18, 2017 | Uniden Office Equipment & Supplies
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
Cannot access htc phone with touch screen not working
Touch screen XYZ access has degenerated and is dysfunctional. Only a technical service representative can assist you in fixing the device.
Feb 26, 2014 | HTC EVO 4G Sprint - /
Replacing cracked screen
Insert your plastic pry tool into the seam in the side of your touch and run it along the length of the device to release the back panel from the front.
If your replacement screen did not come with a plastic pry tool, then a small flat-head screwdriver will also work.
Remove the square battery from the motherboard in the front housing by running the pry tool along the sides of it and gently pulling up.
Remove the small piece of black tape from the bottom of the front housing to expose three screws.
Remove the three screws using your small Phillips-head screwdriver. Remove the small screw near the top of the battery connector ribbon as well.
Remove the metal cover from the bottom of the front housing with the plastic pry tool.
This will expose the ribbon that connects the screen to the front housing and motherboard.
Flip the screen-connector ribbon up and gently pop it out. Then remove the two screws at the top of the front housing and disconnect the one other screen-connector ribbon.
This will release a thin metal board at the top of the housing that guards the screen. Pull the metal board out carefully.
Remove the 16 small screws from the side of the screen.
Once the screws are removed, the LCD screen will be free of the housing.
Gently remove the screen and replace it with the new one.
Replace the screws and reassemble the iPod touch the same way you took it apart.
video http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&view=detail&mid=3843F00F64220E3352823843F00F64220E335282&first=0&qpvt=how+to+replace+an+ipod+4g+screen
Nov 05, 2013 | Apple iPod touch
Nexus 4 LG plugged my phone as batteries where dead. Won't come back on. It shows battery charging and has been charging for 2 to 3 hours.
Press and hold Volume Down, and then press and hold Power simultaneously until the device turns on.
Hope that helps!
Nov 01, 2013 | iOttie One-Touch Bike Mount Holder for...
IPod touch-shattered screen, thou can still be used.can u replace the front screen?
yes it is but you will need some certain tools
video
hope this helps
http://www.ebay.com.au/itm/New-Touch-Screen-Digitizer-Glass-Replacement-iPod-Touch-4th-4-4G-Gen-White-/330783433649?pt=LH_DefaultDomain_0&hash=item4d043aa3b1
Au $11.54 + postage Au $2.95 worldwide
im not sure if this is the right one you need
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Oct 10, 2012 | Audio Players & Recorders
Touch pad will not zoom in or out
missing drivers. Go to:
http://www.asus.com/product.aspx?P_ID=h6SPd3tEzLEsrEiS
On the bottom you have "Download" tab. Click, then pick your operating system, when the list of things to download will show up select "touchpad" and download thing which will appear. done
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | ASUS Eee 4G Notebook
Want to remove battery in sprint htc touch phone
This unit rquires special kind of screw driver for mobiles or gadgets. Normally, its a star shape screw driver. You must take apart the unit's casing by removing all the screws for you to dry the unit. There's a cover at the back panel that you must remove first
May 07, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
