Question about Exercise & Fitness
Same issue, replaced batt once now the same thing... replacing the battery is not working now, any suggestions??
  • 297 Answers
What kind of problem are you having?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Jan 04, 2011
Thermostat display reads lo batt replaced batt still reads lo batt
Suggest have battery tested.
Most thermostats cost more to repair than to simply replace them.
Feb 04, 2018 | Heating & Cooling
01 sunfire battery is not charging
I had a similar problem once and it turned out to be the ignition coil. Ran fine cold but once everything was heated up it broke a connection and went dead. I wonder if you might be having the same thing but in the alternator? Just a thought.
Jul 30, 2012 | 2001 Pontiac Sunfire
98 Deville had a dead batt. Replaced, turns over but wont start
Sounds like fuel issue, remove the black plastic cadillac cover on the top of the engine, then find the fuel rail on top, and remove the black tire cap looking thing on the end of the fuel rail. Now you will have to get a fuel pressure guage ($45), and screw it on right there. Or you can also just poke that little valve with a ink pen to see if any fuel squirts out, it should come out with alot of force, it is like a valve on a bicycle, it only lets fuel out when you push on the valve ***. As for the battery being dead perhaps you left your parking lights on? My 97 deville, had a cold start problem, that it took 5 minutes of cranking off and on, to get it cold started, but after it was running it would start throughout the day just fine. I ended up replacing the fuel pump in the tank, and the fuel filter on the rail.
Nov 19, 2011 | 1998 Cadillac DeVille
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Car will not start, just makes a clicking sound.
if when you jump it starts its your batt if if keeps dying it your alternator the clicking sound is your statrer which means thats good try the batt when you buy a new one it will have a warranty soo if it dies because the alt you will get a new one batt for free (the alt charges the batt)
Aug 22, 2009 | 2003 Kia Rio
98 chevy g3500, where is the ignition modual, how do i test it?
your first mistake was buying a reman starter from autozone ....go to napa, oreilly, or anywhere but autozone to buy reman starters
alternators etc ....autozone parts are junk ...
get a new starter motor and replace the autozone one ....
Aug 08, 2009 | 1998 Chevrolet Express
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Ebel Wave lady's watch battery
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
Feb 19, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
2001 F350 Charging problems
actually the only thing i can recomend is to have the alternator replace again for warranty and before starting the truck charge the batteries very well with a baterie charger make sure to charge them individually because with a low batterie the alternator has to put a lot of load and might burnt again
specially with dual batterie.
Jun 03, 2008 | 2001 Ford F350 Super Duty SuperCab
Exercise & Fitness Logo
15 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
