Question about NetGear RangeMax WPN824 Router
How do I restore the router back to it's factory user name and password? Since I forgot the setup username and password.
  • 731 Answers
Press and hold the Default reset button on the rear panel until the power light blinks... about 10 seconds
Release the button and wait for the router to reboot
Posted on Jan 04, 2011
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
What would username and password on login setup for Linksya wireless router?
factory default password and username
User: leave it in blank Password: admin
or
User: admin Password: admin
Mar 14, 2011 | Computers & Internet
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
I forgot the username and password of my dir-600 2.03 ver
Use the reset button on the back of the router. Hold the button down until the router resets and then re setup the router. You may need to unplug the router from the LAN and wall. Hold the reset button down and plug the power cord back in. Continue holding the reset button and let go after a few seconds. Plug the internet cord back in and re setup. inlutero.jpg
Feb 28, 2011 | D-Link DIR-600 Router
Forgot my password and user name
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 21, 2011 | NetGear WGT624 Wireless Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
Rest password on DNA-A211-I ADSL2+ Modem
hi..
the only way to restore the router is to hard reset the router,which will reset the router to the factory defaults and then setup the router as the first time installation and the default username and password will be restored,i kno this is much of a work to reset the router and again setup the router like 1st time installation but this is the only way to retrieve the default user name and password..
vedhick
Jan 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I hooked up my wireless and dsl router again and I forgot the password to get into it
Try a hard reset (small button on the back of the router, usually recessed and accessably using a paperclip to push it in)
This will restore the router to factory settings. The password and user name will revert back to the factory ones which for netgear is
User Name = admin
Password = password
Then once your into the router settings you can set the username and password to something you want.
Hope this helps
Aug 15, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Forgot my user name and password
The default username for the router is admin all lower case. The default password, is blank.
Try this first - if that does not work, you will have to set the router back to factory defaults, then do any setups on it that you had before.
To perform a reset on the Actiontec - Press and hold the reset button on the back of the Gateway for 15 seconds. This will reset the unit back to its factory default settings.
Mar 29, 2008 | Actiontec GT704WG Wireless Router...
NetGear RangeMax WPN824 Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
