Question about Whirlpool MH3184XP Microwave Oven
Vent fan turns on if you open the door or if you turn on the light. Do I need a control panel?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
no you can have many different issues, other than a control panel. and other than that i must give you this warning, and good luck
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
Fan blows when doors open
One of the three door switches has failed and will need to be replaced. You would need to access behind the control panel to check them and or replace it. Good luck
Feb 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Vent fan will not turn on.Display keeps showing vent fan off
Did this occur after a failure of your cooktop lights?
Or is there is buzzing noise present when the oven is not operating, or when the door is opened?
If so, then the problem is on the control panel, which can be repaired economically.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave fan turns on when door opened
The problem is caused by one or two bad door switches.
Apr 27, 2012 | Microwave Ovens
Fan does not shut off unless unplugged
If the light and fan come on when the door is opened normally, check the door switches.
May 19, 2017 | Kenmore 80809 Microwave Oven
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad problem
The most likely causes are a bad door switch or a problem with the control panel assembly. You can find critical safety information plus our information file on checking and replacing door switches at our site, via our poisting here: http://tinyurl.com/yzjozk If you need control panel repair, we do that for $32.50 nationwide.
Jan 24, 2007 | Kenmore 62622 Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Whirlpool MH3184XP Microwave Oven Logo
35 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
