Question about Element Electronics E750-DPD Portable DVD Player
I'm unable to find a replacement for my broken cable. It's the the yellow,green,black cable that connects the 2 screens.
Randomly says 'Component' and screen goes black when watching movies.
you gave very little info to go on. are you using component connection? if so check the green connection for loose or broken cable/connector. or replace the component cable with a new one. if you are using HDMI check for loose connections or replace the HDMI cable
Jan 17, 2013 | Sharp Aquos Televison & Video
The connector that connects to the phone has been broken off from the 4 wires..(RED/BLACK/GREEN/WHITE...On the end of the connector there are 4 holes..I just need to know the order of the wires..THANK U 4...
left to right black red green yellow only two wire operate a phone red and green for one line and black and yellow for the other line so you can run two line down one phone cable as long as red and green are in the center.
Feb 05, 2011 | Computers & Internet
When hooked up led 46" aquos it is black and white
You must only connect a yellow to a yellow a green to a green and etc. You must have a yellow cable going into a green hole. You need an adaptor. The adaptor goes into input 2. The other side of the adaptor is a yellow red and white male cable that will fit into your device.
Sep 28, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Which cables go where???????
RED - YELLOW - GREEN - BLACK -----
1 3 5 7 9
2 4 6 8 10
May 08, 2008 | MSI PM8M-V Motherboard
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Element Electronics E750-DPD Portable DVD Player Logo
65 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
