Question about ASUS P5KPL-AM SE Motherboard
If bios get fail then what to do? " And if its
If bios get fail then what to do? " And if its showing system will shut down within 15 seconds..." Please guide
    Problem Solver:
Heat sink compund pasted in your cpu....?????
Posted on Jan 04, 2011
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
Gateway 504gr bios update failed
You maybe using the wrong version, it's already updated, or simply can not be upgraded.
Unless there is a TRUE need to flash, and usually there is not, I would stay away from. So many people try and fail, only to wipe the CMOS, leaving the system useless. Here is some sound advice on the subject.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 01, 2012 | Gateway 504GR PC Desktop
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
Hi Please my DELL 1555 DVD/CD drive is not showing on "My Computer" window. I have gone to the "Device Manger" window and it is showing a warning sign. The DVD/CD drive is well...
If the issue is software, then this should resolve:
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Reset BIOS Defaults then see if the drive works.
If that has no effect, ensure the drive is detected in the system BIOS and ensure you can boot to the drive using your Windows DVD. If not detected or not bootable then the drive has likely failed.
Nov 22, 2010 | Dell Studio 15 Laptop
System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
May 31, 2010 | ASUS P5PE-VM Motherboard
Laptop randomly shuts down
This problem might be occur due to old BIOS version installed on the laptop.
If your system shut down unexpectedly within 10-20 minutes while playing games or scanning the system which takes high cpu usages then the problem is of BIOS and try to install the new BIOS version.
for that visit the site of your laptop company.
Nov 25, 2009 | Computers & Internet
HP530 shuts down within 15 seconds as it loads XP
Probabpy an XP problem, start XP in safe mode (press F8) as it is loading.
If it runs then it is probably a driver problem. Try restarting in the last good configuration. Keep posting until the problem is resolved.
Aug 17, 2009 | HP Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Mother board problem
First sometimes a PC will automatically shut down if the BIOS settings for temperature set and there is an issue. IE a fan is out and the PC is overheating. If you are sure that is not an issue. Then you can flash or do a BIOS reset by opening up the computer (TOUCH THE POWER SUPPLY BEFORE touching ANYTHING to the motherboard or any internals..this will take away any static you may have before you touch the motherboard). Then look on your motherboard for a jumper for the BIOS reset. You will have to move the jumper to one side to reset it. Then power up your machine, then power it down again and place it back into its original position. This "flashes" or "resets" the BIOS. NOTE: before EVER working internally power DOWN the machine and UNPLUG it!
Jan 28, 2009 | ASUS P5LD2-VM Motherboard
ASUS P5KPL-AM SE Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
