Question about Frigidaire Microwave Ovens
Under the hood light bulbs keep burning out on our Frigidaire Over-the-Range microwave. Model PLMV169DC
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
drumbanger
  • 1199 Answers
SOURCE: Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Posted on Jan 13, 2009
SOURCE: Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
Posted on Jul 13, 2009
joeguest2
  • 2080 Answers
SOURCE: Need a user manual for
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137230en.pdf
And here is a link to the wiring diagram for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/5995451720.pdf
And here is a link to the installation instructions:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137233en.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 25, 2011
My Underlight on my Frigidaire Microwave does not turn off
Hello Michael Fiedler, thank you for your post!
I understand that the light under your Frigidaire microwave will not turn off. Sounds like it could be a possible issue within the switch or receptacle. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. I hope this is helpful. -Matt
Sep 02, 2014 | Frigidaire PLMV169DC Microwave Oven
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need the hood light bulbs...both burned out and I can not find KEI 125V 30 watts...any clue?
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 18, 2010 | Magic Chef CMV1000B Microwave Oven
Digital Light does not come on to when microwave is running
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or you can get a replacement control board (part number AP4358930) for $124.59 plus shipping from the hPros here.
They're our favorite supplier.
Oct 01, 2010 | Frigidaire PLMV169DC Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
I need mounting instructions for frigidaire model plmvz169gcb
You can download Frigidaire owner's manuals and installation instructions here.
Jan 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Panel control
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 19, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
355 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
