Question about Brother HL-4040CN Laser Printer
Printer keeps saying to clean the corona wire. I cleaned it several times but the message keeps popping up.
  • 1,218 Answers
To clean the corona wire in the brother laser printer, it said to remove the drum/toner assembly from the printer. This is very easy to do, you simply pull down the front of the printer, and press a small green tab down and pull. Then the toner and drum assembly will quickly come out.
After that, it says you must clean the corona wire by moving a small green square back and forth several times. It seemed kind of strange to me, but I did it anyways. In the upper right corner of the drum/toner assembly, there is a small green/blue square that can be moved back and forth. I did this several times.
I then placed the unit inside, and the error message went away for a minute. However it still wouldn't print and the error message came right back up. I was a bit frustrated since I have only owned this printer for about 2-3 months.
But then I realized something: The toner button had been blinking for about a month. I had already purchased a high yield black toner cartridge for the brother laser printer (Tn-330/TN360). I purchased it online, and had it stored for when I eventually ran out of toner.
I thought perhaps the error message had something to do with the old toner. Maybe it was out?? So I once again opened the front of the laser printer, and removed the toner/drum assembly. I pressed a green tab, removed the old toner, and then added the brand new high yield black laser toner cartridge. The whole process was very simple (you gotta love today's technology).
I then quickly "cleaned the corona wire" a few times again just to be safe. I re-installed the toner, and the printer was up and running. So apparently it will throw this error when you are out of toner. Now the printer is running great again, and I really like this printer.
If you are still using an ink jet printer, then you are living in the stone age. I was reluctant to buy a new laser printer, but now I love it. The toner only costs $30-60 and lasts for months. I print hundreds of labels out each month-just to give you an idea of how long it lasts.or get more information Call +877 889 6859 for detail.
Posted on Jan 04, 2011
Why does my Brother HL 3070CW keeps saying "drum error, clean corona wire on drum". I have cleaned all the corona wires, but still getting the same message.
You have to replace your drum with a new one. It has been worn out and cannot keep the primary charge, resulting poor image quality
Jun 13, 2014 | Office Equipment & Supplies
Printer Status LED is Red and Drum Light is Yellow
Hi, this error shows when the corona wire is dirty, some times I clean the corona wire with a small screw driver pressing the corona wire down and slide the screw driver to the both sides also once you clean in the up I press from the side and slide the screwdriver after that with a cotton swab with isopropyl alcohol slide from side to side, or replace the drum unit and reset, if you install a new toner, there is a mechanic control for reset the printer toner counter, this only works the first time that you install the cartridges, for example If you install the cartridge in 1 printer and then move to other printer the other printer keep the counter for the old cartridge, if you are sure that your cartridge is new you need to open a return the gears to is original position in order to install in another printer.
Jul 26, 2013 | Brother HL-5240 Laser Printer
My DCP 7020 printer keeps saying dust on the drum. Clean the corona wire. I did this several times and keep getting the same message.
If you have a knowledge in disassembling the drum assembly unit then do it their you can see some other parts to be cleaned but be careful for these are sensitive parts.
Steps:Carefully remove the lock both ends, then pull it up and start cleaning inside using an artist brush you can also remove each parts inside if yuo want to individally clean and see to it no toner powder left in the dust collector and assemble again with extra care. Good luck
Note: Dont use brushin OPC drum, best soft cloth instead
Jan 04, 2011 | Brother DCP-7020 All-In-One Laser Printer
Corona cleaning does not solve error message
You will need to replace the drum unit on the printer.
May 13, 2010 | Brother HL-2040 Laser Printer
When I turn it on I get a message to clean the wire on the drum. I clean it but I still get the same message. I just replaced the drum a month ago. I cannot use the printer because this message keeps...
You run the little blue tab back and forth about 20 times, use a can of air to blow toner out of that area, if it doesn't help, you need to wipe the corona wire carefully with a q-tip. Also wipe the electrical contacts on the sides of the drum and inside the printer on the right and left sides where the drum sits. After all that press go 3 times for a printout and see if it is telling you the drum clean error, it will show the last 10 errors.
Dec 15, 2009 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
CORONA WIRE CLEANING
SWARNAVA has the most common wrong answer to this problem...
I am waiting for a firmware update to fix this issue. The only solution is repeatedly removing the drum/toner, moving the green cleaner back and forth, putting it all back together loosely, putting it in the printer loosely, and closing the door gently. Hold down the blue button until all the lights glow, then release. If you're lucky you only have to repeat this process a dozen times until you trick the sensor into not giving false readings.
Jan 20, 2009 | Brother HL 2140 Laser Printer
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Dust on Drum
The corona wire can be cleaned as follows:
Take the cartridge out of the printer.
As you are holding it in the same position as you took it out of the printer, in the uppper right hand corner there will be a small light blue / purplish tab with a triangle on it. The triangle points to another triangle on the black part of the cartridge.
Slide this blue tab back and forth several times. You have just cleaned your corona wire.
Make sure you slide the tab all the way back over to the right before putting the cartridge back into the printer.
Jul 18, 2008 | Brother MFC-7820N Laser Printer
Brother HL-4040CN Laser Printer Logo
583 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
