Question about Remote Start System
Installed viper starter in a 2005 Chrysler 300 Limited,only to have the dash lights go into test mde when ever.The horn alarm would sound or go off at random starting times.After two weeks of this **** retailer who did install...uninstalled remote starter.I since found out any 05' or newer chrysler/jeep needs a chip installed in the computer and programed.Something to do with the new electrical system from chrysler.Whats the scoup....!
  • 42 Answers
The tech must not of known what he was doing. That car is a straight up car and I have done 100's of these cars. Your car does have a chip in the ke that it must read in order for it to start but any tech should know how to bypass it so that your car doesnt have problems. Ford has had this technolgy out since 1997. I think he had more of an issue trying to wire up the relay for your second start wire and second accessory turn on.
Posted on Feb 04, 2011
Driver side door ajar light comes on 2006 chryler 300 c
alarm will obviously sound because the anti theft device thinks door is open...maybe it doesn't think ...it mis detects
check the door light switch and how it is affected by closing opening of door. look at what happens at the contact point.
It may be something mechanical, or something electronic/electrical
empirical testing should reveal the answer
Jul 07, 2015 | 2006 Chrysler 300 C
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
2005 dodge dakota horn honks while arming vehicle with Viper alarm instralled
You need to look under the dash for the model number then contact viper support
Feb 17, 2012 | Vehicle Parts & Accessories
I have a Chrysler 300 (2005) Tourning. The car will not crank up. The lights, and radio will turn on. Do you have any ideas?
Check the fuses first. Especially, look for a fuse for the starter or starter solenoid or just solenoid. If the fuses are all fine, make sure that the security system is being properly disarmed. i.e. are the batteries in the remote dead? is the key dirty or otherwise malfunctioning? if the alarm seems to be disarming properly, then it's time to troubleshoot the starter motor....
Sep 14, 2011 | 2005 Chrysler 300
I have a 2008 chrysler 300 and I installed an alarm system. I connected the factory horn to the alarm using a relay. I installed a relay under the hood and got the power from the battery the problem is...
you have either a blown fuse or the factory wire harness isnt connected to horn first check fuse owners manual will have location and description of fuses if ok retrace your steps when you hooked horn to new alarm you disconnected wire at horn or you cut the wire to access horn wiring
hope this helps
plz vote leave a comment if need more help reply
Jan 18, 2011 | 2008 Chrysler 300
Car battery installed backwards - reversed polarity. blew whole bunch of fuses. now remote starter not working nor the door lock. viper 771X alarms works just fine. any idea if there is a fuse in the...
I'm sorry to hear that that happened to you. I think that when opposite polarity blows a bunch of fuses, and smoke pours out of the dash, it's a worst case scenario.
I've seen what electrical fires can do to wiring, and it's not pretty.
I'm not sure about the Chrysler 300 from 2005, but commented anyway.
Good luck on repairing this problem. You may need the assistance of an auto electric shop.
Dec 12, 2010 | Chrysler 300 Cars & Trucks
Viper car battery went dead now alarm light on
you are in valet mode.
find valet switch under dash or driver kick panel.
turn key on
then push the valet switch for a few seconds.
light should go out and then function properly again.
Jan 16, 2010 | Vehicle Parts & Accessories
I turn key but car won't make a sound
you may have to bring it to a dealer to reset the anti theft system,see also if the relay for the starter and PCM are gtting power.
Sep 10, 2009 | 2005 Chrysler Pacifica
Do 2005 chrysler 300 base come with an alarm system.
lock the doors from the switch with the door open. That turns the included factory alarm on.
Dec 08, 2008 | 2005 Chrysler 300
Remote Start System  Logo
140 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
