Question about Samsung CLX6220FX COLMON MFC Printer
Paper jam at exit area 6220 - Samsung CLX6220FX COLMON MFC Printer
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
  • 208 Answers
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Posted on Feb 04, 2008
SOURCE: paper jam at output error code 241.01
replaced faulty fuser and now working ok
Posted on May 19, 2009
rtrahan
  • 741 Answers
SOURCE: Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Posted on Jun 02, 2009
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
After picking up several pieces of paper at once and jamming, the printer now says there's a jam in the exit area. The paper jam I removed from the input area didnt leave any bits behind so I dont see...
You didn't mention your printer make/model but typically this is one of two issues. Either there is a jam (and it can be the tiniest of pieces of paper) or the printer "brain" needs to be reset. This can usually be done by holding down a sequence of buttons on the printer while turning it on. However, all makes/models are different so you best bet is to check the printer manual for how to do this.
Apr 27, 2011 | Office Equipment & Supplies
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Printer says,"paper out put slot, paper is jammed" there is no paper jam, paper will not load properly.
Hello sir; Check the paper exit area there have paper exit senser ,check the senser is on right possition.
Sep 26, 2009 | Canon Office Equipment & Supplies
I am getting an error on my Samsung SCX 6320 saying that there is a paper jam when there is no visible paper in the machine. It had jammed, I removed the paper with no tears or rips, but it still has the...
its may be the problem related to Two causes....
pls. check the Main Frame paper feeding gear was brokned or not ?
check the paper exit Pully in the exit area....
Jul 09, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam at exit
Jun 02, 2009 | Samsung CLP 300 Laser Printer
Samsung CLX6220FX COLMON MFC Printer Logo
1,159 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
