Question about Kenmore Elite HE5t Washer
GETTING ERROR CODE F17 ON KENMORE ELITE HE5T WASHER? ANY IDEAS?
the dr
  • 447 Answers
SOURCE: Kenmore Elite He5t Washer Error F24
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
  • 91 Answers
SOURCE: kenmore elite washer he5t error
remove bottom panel 3 screws 7mm get bucket and alot towels, turn pump filter clockwise and remove all debris from inside pump now close it up nice and tight should solve youre problem
Posted on Jan 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: washer starts to begin wash cycle then says suds then error code f35 appears then washer shuts off
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
The "SUDS" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) – 0 ohms
Pins 3 to 4 (Overflow) – 0 ohms
Pins 4 to 5 (L1) – 0 ohms
Pins 4 to 6 (Empty) – 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: HE5t washing machine flashes F35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 26, 2010
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
Anyone know what code F17 means on my HE5t washer and how to fix it
sorry no i/we dont know i have seen this question in mant various froms here this morning we all know F25 code but i and suspect everyone has no idea what the F17 means since i have seacrhed and can not find any reference to it anywhere on the various sites i use to look up Whirlpool Duet error codes...nor in my years in the fileld servicing Duets have i ever seen the F17 code
Sep 28, 2011 | Kenmore Elite HE5t Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Error code f17
Sears are a department store not a manufacturer, they contract other manufacturers to build the appliances for them and these are then sold under the Sears/ Kenmore brand.
To find who made your appliance, check the first three digits of your model number against the list below and this will give you the manufacturer of your appliance.
There is a site to help identify you washers "real" maker
The Link is here to cross reference it.then look up f17 and f25 on that make and model for better results
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
the Sears/Kenmore part is almost in the middle of the page. Then keep me posted by adding comments if you have any other questions
I hope this helps you out
8-)
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
179 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
