Question about Symphonic SL2940 VCR
Can't get the timer record to set. The tape ejects when I turn TV off. There is some trick and I do not have the manual to figure it out.
    Novelist:
  • 128 Answers
Try a new tape, or put a piece of tape over the hole found in the back of the tape you are using. If the record safety tab is still present it may be bent. A piece of tape will rectify this too.
The tab is there to protect the tape from being recorded over by accident. If removed or bent slightly, the vcr will detect it and will not record on the tape.
Most VCRs will eject the tape, or show some kind of error message.
Posted on Jan 04, 2011
MY RCA VCR - TIMER LIGHT ALWAYS FLASHES. WHEN i TRY TO RECORD OR TURN OFF VCR IT EJECTS TAPE.
If it plays a tape OK, then it could be that you have a timer set. In which case clear it! Or that you are using a blank tape where the slot at the back is open. If you are using a blank tape which is good and it still ejects the tape after setting the recording. Then it's likely the recording tab sensor - that detects the slot at the back of the tape - is either bent or broken.
Feb 22, 2013 | RCA Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My timer recording funtion isn't working
you might have an object stuck inside or the belts need to be changed. also the idler could cause this problem. hope this helps.
good luck.
Feb 08, 2008 | Televison & Video
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
I cannot get program recording with timer set.
Problem seems to be related to the "write protect" tab on the tape not being sensed. Is the tab removed? That would explain things there...accordianman
Nov 28, 2007 | Zenith VCS442 VHS VCR
Symphonic SL2940 VCR Logo
82 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
