Question about DCS RGS-366 Professional Gas Kitchen Range
What kind of double sided tape do I need to repair the glass door that has dropped?
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
Where do you get the double sided tape to stick the glass door back on oven door?
Far as I know the glass oven door is sealed with special silicone putty that is resistant to a temperature of 300 Celsius .
Previously, the required perfect clean the surface with alcohol.
Dado
May 23, 2014 | Electrolux EOG9330 Gas Double Oven
How to attach loose scanner glass
The glass plate in scanners is almost always held in by some kind of 2 sided adhesive tape AND plastic clips. Th adhesive probably failed, but the glass plate is probably at an angle and not resting on the plastic clips correctly. These act as a failsafe in this very situation, so the glass plate doesn't break or damage the scanner guts.
Anyway, if you want a permanent repair, this is the tape you should use: Amazon com 3M Scotch Heavy Duty Mounting Tape Clear 4010 Double Sided...
It will definitely support the weight of the glass and then some. Be careful with this stuff, it will remove paint (or worse) from drywall. You should only need 4 strips, one for each edge of the glass. Apply it firmly to the glass, then stick the glass onto the plastic bracket.
Apr 13, 2014 | Epson Perfection 1240U Flatbed Scanner
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Dec 06, 2007 | GE Profile JT952 Electric Double Oven
How do I access the underside of the Flatbed scanner to clean it?
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Nov 08, 2007 | Umax Astra 1200S Flatbed Scanner
DCS RGS-366 Professional Gas Kitchen Range Logo
80 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
