Question about HP PhotoSmart 7760 InkJet Printer
Printing is not clear - HP PhotoSmart 7760 InkJet Printer
  • wongman2 Jul 09, 2008
    printing is blurry
    Problem Solver:
  • 10 Answers
Hi There
Just follow the steps in the document, and that should fix the print quality problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00291420&cc=us&lc=en&dlc=en&product=305375
If you are not able to follow the steps, please respond so that we can try some other steps.
Regards
Santhosh
Posted on Jan 27, 2009
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying.
First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using?
what are you trying to print on the front and back?
Feb 17, 2015 | Fargo Pro L ID Thermal Printer
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
Print not clear
from printer properties --> preferences --> device options -->
1- speed setting ( set it to low speed to have clear print) and
2- Head setting ( set darkness to upper digit to have clear print)
Jun 18, 2013 | Star Micronics TSP100 Thermal Printer
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
The printer prints one page clearly. Given 3
Try to reset your printer to factiry default from it's main menu. and check and you can try uninstalling and reinstallling your printer as well/
Jul 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Won"t print, was using printer before
Yes, you may need to clear the print queue by restarting it and then try printing again. Its like rebooting your computer. Go to control panel>administrative tools>then Services. In Services, you'll see a list of programs, scroll down to Print Spooler then right click on it and choose restart or stop then restart. This will clear your print queue. Then try printing again. If that did not clear it and allow you to print, then let me know and we'll try another way. Pls rate this solution.
May 07, 2009 | HP Photosmart C5280 Printer
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Hi there!!!! my canon mf4140 keeps flashing error ... load correct paper and I have! it prints the same over and keeps flashing
Clear the print job on the computer,and clesr the print job on your copier.
You clear the print job by pressing the monitor button(the one with the diamont shape and eye)select printing jobs and and clear it by selecting the left arrow(yes)
Print the specific job again but first make sure the paper size settings on the file you print is correct.
You can check your papersize settings for the copier in the printer propperties aswell.
Jan 09, 2009 | Office Equipment & Supplies
I have been using sharp copier- table size(SF-2218). but recently a red image in form of a man is viewed which is stopping the copier from warming up.
Dear sir; The symble of red man, means need PM service, you need to replace DEVELOPER,
slide out developer unit and remove toner hopper(2 screw),Empty old developer,replace with full bag, reassemble, install back to the machine. power on, press "clear", "pause", "0", "pause" keys, then enter 25, press print, enter 2, press print,machine will run for 3 minutes, the "pause" key also call "interupty" key, when machine stop then press "clear" then enter 20 press "print" enter 01, press print, enter 0, then press clear key enter21 press print enter01 press print,enter 0, press print press clear twice to end the simulation.
If you not clear or need more help just email me, I always around, good luck!
DON'T FORGET GIVE ME A RATING
HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Office Equipment & Supplies
Wrench and Snowflake
wrench means service problem. "snowflake" I assume you mean the developer symbol. Machien on - depres the clear key then the expose key then the clear key again then the expose key you are now in simualtion mode. depress 20 print 01 print this will turn of the maintenance or wrench code. Depress 24 print 06 print will clear the developer. turn on and off
Apr 09, 2008 | Toshiba e-Studio120 Copier
HP PhotoSmart 7760 InkJet Printer Logo
77 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
