Question about Maytag 24 in. DWD1500A Built-in Dishwasher
I have a magtag quiet 100 series that has a broken handle but still shuts tight and seems to lock yet. Problem seems to be that the rinse only light will stay on for quite a long time and won't let me hit the wash button. When the rinse only light does go off, if I hit the wash button it starts but then switches to rinse only. Sometimes I can get lucky and get it to stay on wash after the rinse button is off for some time. Any suggestions?
4 Suggested Answers
  • 297 Answers
SOURCE: Quiet Series 100 dishwasher, where do I put the
in the plug, the hole is how it sprays the dishes.
Posted on Jul 21, 2009
dblred
  • 68 Answers
SOURCE: I have a maytag quiet series 100 dishwasher and it
the control panel is locked. dont know your model number to tell you what buttons you hold to unlock it, but some models have a lock button you hold down for 3-5 seconds. other models just have a lock light, and have a line indicating 2 buttons that you hold down for 3-5 seconds. if you cant find which buttons to hold down, refer to your owners manual. once the control panel is unlocked, it will run again. shane
Posted on Sep 01, 2009
SOURCE: The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
Posted on Dec 02, 2009
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do I replace the latch on my maytag quiet series 100 dishwasher?
Unfortunately, the Maytag quiet series models have plastic latch handles that are prone to crack after time.
You should be able to order a replacement handle through a distribtor.
If you can, unlatch/open the door. Using a star screwdriver, unscrew all the screws on the inside of the door frame.
Once all the screws are removed you should be able to separate the inside of the door from the latch assembly.
From there you'll need to squeeze the latch handle together and replace it in. I'll warn you that it feels like you have to squeeze the thing so hard you might break/crack it on your own. It is a hard/tight fit if I remember correctly.
One last thing you may want to do to is check the food grinder in the middle of the washer. Sometimes the cracked pieces of the latch can end up there stuck in the grinder causing it to be louder than it should.
Hope this helped.
Nov 06, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 200 Handle Broken
Remove the torx screws around the inside of the door and pop off the inside cover. Remove two screws and unplug handle. Remove broken handle. Insert new handle and replace screws.
Sep 20, 2009 | Dishwashers
I have a maytag quiet series 100 dishwasher and it will not run a lock light comes on and i have replace a broken handle assembly but light stays on
Sep 01, 2009 | Dishwashers
May 29, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. DWD1500A Built-in Dishwasher Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
