Question about Sony Playstation 3 (PS3) Console
My name is mitchell hamby and on my ps3 when i go to my internext settings on the main menu of the ps3 and it says i have 100% signal on it yet when i get on call of duty black ops my game keeps on glitching and saying that i only have one bar worth of signal towards my wireless router please contact me back on how to solve this problem at mitchellhamby@yahoo.com
  • 839 Answers
There are series of problem in ps3 which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the ps3 repair guide that will help you a lot....
Click here to download PS3 repair guide
Posted on Jan 04, 2011
Can i reboot my ps3 using lenux boot disk
Yes, Ofcourse.
Instructions
    • 1 Select and download a Linux distribution to download. Your options are Ubuntu, Fedora, OpenSUSE and Yellow Dog. Ubuntu and Yellow Dog have better support for PS3 than OpenSUSE and Fedora. Links are provided in the first Resource.
    • 2 Locate the boot loader included with your Linux distribution of choice and rename it to "otheros.bld" so the PS3 recognizes it. Your bootloader is either named "kboot" or "petitboot" followed by a version number.
  • Create a folder named "PS3" on the CD or Flash drive. Create another folder named "otheros" inside the "PS3" folder. These folder titles are case-sensitive--enter them exactly as they appear here.
  • 4 Save the "bootloader.bld" file in the "otheros" folder. If you are using a CD, burn it now. See the second Resource on how to burn a CD using tools included in Windows.
  • 5 Insert the Flash drive or CD into the PS3.
  • 6 Go to the "Settings" column of the PS3 main menu, select "System Settings," then "Install Other OS." The PS3 then searches for and starts installing the boot loader from the Flash drive or CD.
  • 7 From the "Settings" column again, select "System Settings," then "Default System." Choose "Other OS" from the options listed on the right.
  • 8 Burn the .iso of your Linux distribution of choice to a CD, if you want to boot the PS3 from a CD. If you're using a Flash drive, see the third Resource on how to put a running Linux installation on a Flash drive.
  • 9 Remove any disc already in the PS3 and turn it off.
  • 10 Insert the CD or Flash drive. The Flash drive goes into one of the PS3's USB ports, located on the front face, in the bottom right-hand corner. If you insert a CD, the PS3 automatically turns on.
  • 11 Turn on the PS3, if it hasn't turned itself on already. Select your Linux distribution from the boot loader menu to boot the PS3 from the Flash drive or CD.
  • Jun 05, 2013 | Computers & Internet
    My Viore 42" LCD HDTV's HDMI inputs currently make the TV's picture signal intermittent when reading a signal from my comcast cable box and a few functions of my PS3. How can I fix this?
    You might need a firmware upgrade. If there isn't one,then you might have a defective main board, or your set is not 100% compatible with your other items.
    Mar 21, 2013 | Viore 42" Class 1080P 60Hz Lcd Hdtv
    Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
    For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
    Dec 08, 2012 | Linksys Wireless-G WRT54G Router
    My playstation three will not connect to the internet even though i just purchased a new N gaming router thats covers the whole house, and my ps3 has lik e60 percent signal strength and will not sing me in...
    Well 60% is not really strong honestly for the online gaming. My suggestions for you would be 1 get a cat 5 cable and run it hard wired. But if you would like to keep it wireless (or even wired for that matter) you also would want to do these steps. 1 Enter your router main menu usually in the internet search bar type 192.168.2.1 or 192.168.1.1 one of these should work for you. After you enter the Router main menu take a piece of paper and jot down some information, Main IP for your Router (the one you used to enter the main menu) DNS 1 and 2, and Default Gateway. Now you have this information Find out the DHCP range of your router usually somewhere around 192.168.2.100-.149 roughly. These are the automatic assigning IPs.. Now you have this information go to the Gaming and Accessories selection of your router. You want to go to the DMZ portion now. Ok now assign an IP outside the DHCP range in example give I would go 192.168.2.160 now that you have this typed into the DMZ write this one down as well, this is now what you want to assign to your PS3 as a static IP. OK now your ready for the PS3 side of things. PS3 main menu, settings menu, Network settings menu, Manual set up or Custom, when it will ask you for the above information Static Ip address, and the other info from before enter it exact.. Now once your done with all that do a test.. This should help out tremendously.. Happy Gaming.
    Feb 24, 2011 | Sony Playstation 3 (PS3) Console
    Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings....
    Hi kdfrance
    Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
    Try turning off media server on ps3 Go into the PS3?s Settings menu and navigate to Network Settings - Media Server Connection disable it thats my first idea which could be causing the issue..Secondly unplug your modem/router for 15 sec then plug back in...THEN FOLLOW STEPS
    1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
    2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
    3. Select "Wired Connection" or "Wireless Connection", and then press the "X" button.
    4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
    Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
    Hope this info was helpful cheers nikki
    Jan 20, 2011 | Sony Playstation 3 (PS3) Console
    When ps3 is turned on the screen remains blank? something happens because the message on the screen "no input" disappears but the main menu never comes up.
    You can try to hook up your PS3 to a different output and if it does the same, you have to replace your cable connecting your PS3 to your video output device. It is saying no signal because your output device might not been able to detect the video signal your PS3 it sending due to a bad cable. Hope it works.
    May 09, 2010 | Sony Playstation 3 (PS3) Console
    No image/sound when sony ps3 is connected to onkyo 875
    I've had problems with my Onkyo receiver too.
    Firstly i suggest going into the Onkyo setup menu. Make sure that in "source settings" i think that's the menu option) that the input e.g. dvd is set to receive HDMI. then go into the settings for DVD and ensure that resolution is set to auto, then go into the monitor out settings (option 1 on main seyup menu) and make sure that main monitor out is set to HDMI and auto resolution.
    hope this helps,
    Aug 13, 2009 | Onkyo TX-SR875 Receiver
    Ps3 playing BD in 720
    first try to reset the video refresh output by holding down the power button with the switch in the back on. hold the front power for 13 secs ..you should hear two beeps one 6 secs after the other. if this doesnt work reset system settings on the XMB menu (all the way to the left)
    Nov 10, 2008 | Sony Playstation 3 (PS3) Console
    Cant see ps3 main menu
    when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
    Feb 26, 2008 | Sony Playstation 3 (PS3) Console
    Connection to ps3 drops in and out
    GO to network settings...Check out Settings and Connection status list...make sure everything is enabled, wireless, and Automatic....reset your connection..and ur router....turn off the WEP ...security disable....
    internet connection : Enabled
    connection method : wireless
    signal strenght: 100%
    SSID : (name of your wireless router)
    Security: i set NONE....no one really cares to hack ur PS3 ppl turn this off
    Address settings : AUTOMATIC
    Feb 11, 2008 | NetGear DG834G Router
    Sony Playstation 3 (PS3) Console Logo
    55 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
