Question about Epson R1900 Printer
CD slid off the CD tray for printing and can't retrieve the CD from inside the printer. Should I remove something from the rear of the printer to retrieve the CD? Just bought the printer on October 21, 2010. SN# KBQE048699. I think I can see the silver CD by looking down through where the paper feeds. HELP!
    Novelist:
    Scholar:
  • 111 Answers
Yikes!
You might disconnect the cord and remove the paper and anything loose.. and try to lift the printer up and shake it out (since you can't really reach it). The print cartridges should be locked in place so they shouldn't fall out. The paper tray may rattle around but it should also be secure, even if it slides a bit.
Try to shake it gently to get the CD out.
Barring that effort, you'll probably be best advised to take it to a technician who knows who to get it open properly, and more importantly how to get it back together. 8^)
Posted on Jan 04, 2011
My Epson Artisan 810 is blinking (power botton and screen). It is showing an errormsg that says "a printer error has occurred..." I have called Epson, after a long list of troubleshooting items...
I had a similar problem. It turned out that something was jammed in the machine, and the CD tray had slipped out of place. Unplug the machine and check the path of the CD tray. Make sure that there isn't anything in the way. Don't force anything. I also had a problem where it was printing a dvd and it disappeared. It had slid part way into the back. It was jammed in there for several months before it caused an issue. The repair person, just removed the back part of machine by pushing the tabs and removed the stuck dvd.
Jun 20, 2011 | Epson Artisan 800 All-In-One InkJet...
I'm trying to figure out how to load #10 envelopes to print.
Generally, since you have not mentioned what printer you are using, remove all the paper.
Slid the enveople into the bottom of the paper tray, face side down (flap up) and the flap to the left. Push the envelope to the right side of the tray and as far forward until it stops.. On the left side, you may have a rail that will slid to the right against the envelope.
or The paper tray may have a slot on the right near the back. Slid the envelope into that slot, flap up and to the left, as far as it will go.
Once the envelope is put in place, run the software that you use to print.
Jun 03, 2011 | Office Equipment & Supplies
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Canon mx 860 will not print from rear tray: gets
    From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
    Oct 10, 2009 | Office Equipment & Supplies
    HP 6540 Lights flashing can't print
    This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
    The printer might be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of the printer.
    There might be a paper jam
    1. Press the Resume button. If the paper jam does not clear, then go to the next step.
    2. Push the two latch handles on the rear access door toward each other, and then remove the door.
    3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
    4. Replace the rear access door.
    5. Press the Resume button.
    If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
    1. Turn off the printer.
    2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
    3. Remove any paper inside the printer.
    4. Open the duplexer.
    5. Remove any paper from inside the duplexer.
    6. Close the duplexer, and then re-attach the duplexer to the printer.
    If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
    2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
    3. Remove any paper that is inside the printer.
    4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
    5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
    1. Tilt the Small Paper Tray
    2. Open the lower door
    6. Remove any paper that is inside the accessory.
    7. Close the accessory, and then secure the back lever to close the accessory.
    8. Re-attach the accessory to the printer.
    Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
    Canon MP810-CD-R Tray loading-printing problem
    I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
    Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Laserjet 4700 Tray 2 stuck will not pull out.
    You possiblely have something loose in the tray or something broke. Find something metal and thin, like a hack saw blade, and stick it through the slot between the drawer and printer and see if you can feel the obstruction, and if so try to move it out of the way. Something is catching on the printer frame and drawer.
    Feb 27, 2009 | HP LaserJet 4700 Printer
    Epson stylus r1800 problem with printing on cd/dvd
    Try this :
    Disconnect the printer from the computer.
    Turn it off & make sure the CD/DVD tray is closed then turn it back on.
    Here's generic instruction for you:
    If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
    Recommendations:
    -Don't force the CD/DVD tray into the printer.
    -Make sure your printer is powered on, and the output tray is in the upper position.
    -Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
    Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
    CD/DVD LOADING:
    1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
    2. Push in the paper support extension on the printer, and close the paper support.
    3. Push in the output tray extensions, but leave the tray open.
    4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
    5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
    6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
    7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
    General tips for CD and DVD printing:
    -Burn data/video/images onto CDs or DVDs before attempting to print on them.
    -Do not use thermal-printable or regular CDs or DVDs in the printer.
    -Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
    -All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
    -The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
    -Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
    -Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
    -The Epson Print CD software works best with JPG images and may not import some TIFF images.
    Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
    Cd tray error Canon Pixma MP810
    Sorry a little late only just read your problem.
    The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
    May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
    Will not print cd covers
    Describe what YOU call CD covers? There is an anomaly here. Are you simply printing onto a4 paper for jewel case inserts or do you mean actually printing onto the CD.
    Jun 16, 2007 | Epson RX620 All-In-One InkJet Photo...
    Open Questions:
    See all Epson R1900 Printer Questions
    Epson R1900 Printer Logo
    159 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
