Question about Garden
Mtd ride on mower wont turn right but turns left cant see anything broken or bent thanks
5 Suggested Answers
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 89 Answers
SOURCE: Removed bolt but still can't remove rear wheel on
they sometimes are very haed to get off some wheels have two holes on the rim you have to use a gear puller
Posted on Nov 05, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
  • 5 Answers
SOURCE: My mtd riding lawn mower won't go into gear...
Yes , this is what I had- the vari- pully was stuck and wouldn't move up or down and keep pressure on the belt. once I sprayed it with wd40 it started moving up and down ok- and would shift ok-
Posted on May 24, 2010
My mtd riding guarden tractor has a left and a right drag link the front wheels go in opposit directions how to fix them
sounds like one or both spindles are bent or came unwelded
check the spindles over carefully
check rods going to them may also gotten bent
Sep 10, 2015 | Mtd Garden
How do I replace the steering gear on a Ranch King Riding Lawn Mower
mower wont torn to the right t will only go left ,wher do begin to fix ths
Apr 21, 2012 | Mtd Garden
While making a hard left turn the front left tire jammed against the mower body and I had to put it into reverse to straighten it out. Now the mower will not turn to the right. I can turn the tires by...
Nothing is broken,just bent.Go to the front of the mower.Get low.In between the front wheels you will see a bar,or rod.It looks like a tie rod on a car.That bar should be bent slightly but when you hit something with the front tier it gets bent too much.One end of the bar screws in and the other nd is on a clip or pin.Remove one side,which ever is easiest for you.Then just bend the bar back to almost straight.You may have to do this several times to get the turning radius back to normal.
May 23, 2011 | Yard Machines Garden
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd riding mower: right mower blade cutting uneven, but don't see problem
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Sep 18, 2009 | Garden
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower wont start just clunks battery ok
SOUNDS LIKE YOU DUMPED SOME EXCESS GAS IN ENGINE,PULL PLUG(S) AND CLEAN OR REPLACE, CHECK CYLINDER FOR EXCESS FUEL BY CRANKING WITH PLUGS OUT,SHOULD SPIT ANY EXCESS FUEL OUT OF HOLE,REPLACE PLUGS AND TRY TO START.
Apr 08, 2009 | Mtd Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
