Question about Airnet AWR014G8 Wireless Router
Where can i get the firmware for airnet awr014g8, need original or newer or compatible
What are the voltage and current requirements for the power supply for an Airnet (AES205P) 5-Port Ethernet Switch
powersupply should be +5VDC/2.5A The cost of this power supply may not be worth the trouble since this switch is 16 years old. Newer switches are faster and have better firewall protection.
Oct 24, 2016 | Airnet Computers & Internet
I put in a high speed motom and now my router has a weak signal. other devices in the same room can only get a weak signal or no signal.
1-Is it a cable modem? The new ones Cox has out are DOCSIS-3 and if your router is several years old you may want to replace it with a router that is designed for DOCSIS-3. I kept my DICSIS-2 router (3 yrs old).
2-You should do a few speed tests to confirm performance then talk to your internet provider about your connection. I had to have Cox come out to check things and they replaced a component on their side.
3-Do have a friend or a neighbor going through the same thing? I did, we compared notes and got to the bottom of it.
Good Luck
Nov 09, 2013 | Airnet AWR014G8 Wireless Router
Laptop is requesting security key. I have lost my manual
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Mar 14, 2011 | Airnet AWR014G8 Wireless Router
How do i find ssid
should be on a sticker on the bottom
May 26, 2010 | Airnet AWR014G8 Wireless Router
I lost all the passwords want to reset the system to reconfigure it
Turn your router upside down or look on the rear for a small pinhole. It should be labeled "RESET." With the router turned on, unbend a paperclip and insert it into the hole. You will feel a small button inside, which you'll want to press with the tip of the clip. Hold the button down for 10 seconds, or until the lights on the front of the router stop blinking. The router will reboot within about a minute and be ready for configuring from its virgin state.
Remember..default username is admin, default password is admin and default IP address is 192.168.1.1
Nov 19, 2009 | Airnet AWR014G8 Wireless Router
Hi, I lost the drvier CD of it , where can I download the drive. Can not find Airnet's website. Thanks
Gonna hafta junk it, spent 3 weeks trying to find drivers for the router & it's wireless usb dongle, only to find out that once the company went down the **** 2 years ago, they flushed the drivers down with it.
Jan 25, 2009 | Airnet AWR014G8 Wireless Router
Forgotten password
hold down the reset button until the lights flash on and off. Do it about 2-3 times to make sure it will reset. had the same issue.
Aug 16, 2008 | Airnet AWR014G8 Wireless Router
Airnet router
power failure had to change internet password with verizon have to rest my airnet router awro14g/a
May 13, 2008 | Airnet Wireless Broadband Router 108Mbps...
Airnet AWR014G8 Wireless Router Logo
118 people viewed this question
Top Airnet Computers & Internet Experts
JP Services
JP Services
Prashant M
Prashant M
Are you an Airnet Computer and Internet Expert? Answer questions, earn points and help others
