Question about KitchenAid Architect? II S SERIES KUDS03FT Stainless Steel Built-in Dishwasher
No power. Checked circuit breaker. OK. - KitchenAid Architect? II S SERIES KUDS03FT Stainless Steel Built-in Dishwasher
  • 3 more comments
  • cmgwillis Jan 13, 2011
    Still not working. Put a new thermal fuse in. Kitchenaid sent a new control panel. Put that in. Circuit Breaker tests OK. A few months ago, a repairman replaced the inlet valve. Could there be a loose wire as a result of that?
    Thanks. I will try that. So far, I just checked the circuit breaker on the home circuit board.
  • cmgwillis Jan 20, 2011
    New control panel, new thermal fuse, wires all connected, power definitely getting to unit. Still nothing - no lights, nothing. My handyman thinks it could be the float switch. What do you think? I hate to resort to the Kitchenaid repairman. He charges $90 just to show up and he did a poor job replacing the inlet valve when he was here several months ago. It makes a vibrating noise. But, that is another issue (I think).
  • cmgwillis Jan 21, 2011
    I am also wondering if the ribbon cable could be the problem.
    Thank you for all of your help, but I finally had to resort to a repairman. He was very good, actually, and replaced a relay switch and another switch. He thinks that the motor got too hot, or there was a power surge that caused these things to burn out. It is working now.
  • KitchenAid Master
  • 2,605 Answers
Welcome to FixYa.
The issue with your dishwasher is more than likely the fuse inside the control panel...it is all too common with those machines unfortunately.
I've attached a link at the bottom which will show step by step how to repair your machine.
You will first need to retrieve a new fuse, part number 661663
i.e.
they're available at most local brick & mortar parts vendors or on-line at depots such as "repairclinic.com" or "searspartsdirect.com" to name a couple.
In the video the fuse is slightly different so you will not have to cut or splice any wires, just follow the instruction as per removing the panel and turn the power of of course and you'll be fine.
http://www.youtube.com/watch?v=jdlVbTXm8SY
Hope this helps move you forward. Let me know if I can assist you further and I will try and help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Jan 04, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Jan 13, 2011
    Hello again,
    Did you happen to verify the unit had voltage at the fuse when replacing it, or did you ohm out the old fuse for continuity ?
    the other question I'd ask is whether you checked the junction box where the unit is wired to the home circuit ?
    i.e.
    Once you remove the screw holding the cover in place you should see the wires and connectors such as shown here ( for example only...this is from a different model )...
    Remove the wire connectors and inspect for loose or damaged wire connections, this too can manifest in the manner you've described.
    Of course I'll try to help moving forward, let me know what you find as well as what you've done to rule these things out, such as voltage to the fuse/control board.
    I'll watch for your reply.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    **turn the power off of course and you'll be fine...safety first**
  • Mark MacDonald
    OK,
    just remember to turn that breaker off before removing the junction box cover or performing any service requiring panel removals.
    I'll still be here whenever you want to move forward. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jan 21, 2011
    Hello again,
    I've been away for a bit and at the mercy of a "in & out again" internet connection, but I'll try to address the few things you touched on.
    1st) My handyman thinks it could be the float switch. What do you think?
    NO...the float switch has nothing to do with power going to the display nor will it prevent it from running. In the event the float switch where at fault it would either constantly drain or perform all functions with the exception of filling with water.
    2nd) wires all connected, power definitely getting to unit...
    This is very important what I say here...have you checked the power at the control/bi-metal fuse or at the junction box as I mentioned previous, please be specific where you check for power and what method you've used to check for power. i.e. volt meter or test light etc
    You'll need to verify there is voltage...120vac from one wire...either one...to chassis/ground, 0vac across the 2 wires at the fuse...present at first the bi-metal and if not then at the junction box since the possibility of a broken wire between these points can not be ruled out until this is done.
    3rd) I am also wondering if the ribbon cable could be the problem.
    The issue of the ribbon connector being at fault...it is possible , Yes. However, on this machine the ribbon connector is part of the overlay/touchpad assembly as shown below and if it where faulty there typically is still some indication of a display it just won't respond to commands pressed.
    If you look into and confirm the unit having power in all the probper locations and yet there is still no display, I'd consider the ribbon/touchpad.
    There should be a test sheet/tech guide under the machine behind the toe panel. On this sheet should guide on how to test the touchpad...though it can be tedious and sometimes require three or four hands.
    Let me know if any of this helps clarify any of those questions posed or if we need to look into a possible touchpad issue...it is very rare. Good luck.
    Regards,
    Macmarkus :)
No power to master swicth pink yellow wire checked ignition sw there's no power coming from there at all ck breaker ok there's nopower reaching master sw if I supply power there windows work any answer
Pull the power window circuit breaker, and with key in ON, check the terminals for the circuit breaker. One of the terminals where breaker plugs into should have battery voltage with key on. If it does, there is probably a break in the wire from the circuit breaker to the master switch- probably in the door opening.
If the breaker does not show power, you will have to figure out why the ignition switch does not send power to that portion of the fuse panel, including that breaker. That portion would be designated as "hot in run or start". There would be several fuses like that. May need a wiring diagram- on some, the hot wire from the switch trips a relay which sends power to that portion of the fuse panel. On others, there is simply a hot "run" wire that powers up some of the fuse panel.
Jan 03, 2015 | Cars & Trucks
Windows
You need a wiring diagram to
learn the circuit your working on,
& find places to do your testing
Apr 22, 2014 | 2000 Cadillac Eldorado
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Power went off during rain storm unit would not come back on MSZ12UN
May be short circuit. Call electrician to check and replace the fuse or reset the circuit breaker.
Aug 17, 2012 | Mitsubishi Heating & Cooling
All of a sudden dryer won't come on. Checked connection, OK.
Check your circuit breakers. Your unit usually has a double circuit breaker. Find the correct circuit breaker and turn it to the off position to reset it then turn it back on.
Good luck
Sep 29, 2010 | LG DLE2532W Electric Dryer
My power windows do not work. The Haynes Repair Manual mentions that it could be that a circuit breaker was tripped and might need to be resetted manually. Where and how do I manually reset the circuit...
i have diagram for accord 1993, i cant see the breaker you mentioned, if your relay is ok, its mean that fuse #15 have power 12V and when the ignition is on, the relay have supply 12V to fuse #33, if all this ok, the problm is on your power window main switch, connect a wire supply by 12V to white/yellow wire at power window main switch or test this wire if already have 12V when ignition is on
Jun 26, 2010 | 1993 Honda Accord
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT BREAKERS AND SWITCH HAVE 120 VOLTS
Please try the following: 1# Turn on the main power switch(ON/OFF) & press 15amp & 3amp circuit breaker at the same time to re-set the breaker.2#With line voltage is present at ''Main'' 15amp circuit breaker,Check connection between circuit breaker & power switch(ON/OFF).3# Verify line viltage is present at the power supply input connectior 44,(Brown=hot,Buue=neutral).4# Check connection between power switch & 15amp circuit breaker.Hope this will help you.
Mar 17, 2010 | Measuring Tools & Sensors
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
KitchenAid Architect? II S SERIES KUDS03FT Stainless Steel Built-in Dishwasher Logo
244 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
