Question about Troy Bilt Tb70ss Gas Trimmer
I purchased the GC720 TrimmerPlus® Add-On
4 Suggested Answers
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
rycgl
  • 1545 Answers
SOURCE: I own a Troy-Bilt 425cs
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Posted on Sep 11, 2011
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Troy bilt G C 720 manual
I have a new troy built garden cultivator (modelGC720). It won't turn and the motor stalls when the trigger is pulled. Should I return it or is there a easy fix ?
Feb 13, 2013 | Troy-Bilt Troy Bilt Gc720 Trimmer Plus...
I am thinking of getting the BLACK & DECKER 18-Volt Cordless Garden Cultivator. How long is the battery life?
This tool is great! It works wonderfully so it is defintely worth buying. the battery life doesn't last that long though, maybe about 20 minutes. the good thing is if you have other black and decker tools, the batteries all interchange. if you don't have any then i would recommend buying a 2nd battery. great purchase.
Jan 30, 2013 | Garden
I lost the keyfit 30 stroller manual where can i get one... or any website please
hope this help you:
  • Chicco USA - 30lb Cortina Travel System - Adventure Cortina ® KeyFit ® 30 Travel System Travel in style with your baby. Designed especially for the Chicco KeyFit 30 Infant Car Seat, the Cortina Stroller works as a travel ...
    www.chiccousa.com/gear/travel-systems/cortina-30lb-systems/travel-systems-30-adventure... · Cached page
  • Amazon.com: Chicco Cortina KeyFit 30 Travel System in Adventure: Baby Memory Recline seat remembers the last position seat was in when the stroller was folded. Has convenient one-hand fold. 3-position leg rest and flat recline for ...
    www.amazon.com/Chicco-Cortina-KeyFit-Travel-Adventure/dp/B000MAERLG · Cached page
  • Chicco Cortina KeyFit 30 Travel System - babyearth.com The new KeyFit Infant Seat is also available in a Travel System! With its unique Memory Recline seat and fresh, new patterns, you will be traveling in style!
    www.babyearth.com/chicco-cortina-keyfit-30-travel-system.html · Cached page
  • Cortina KeyFit 30 Travel System - Chicco USA - Strollers, car ... Cortina KeyFit 30 Travel System Travel in style with your baby. Designed especially for the Chicco KeyFit 30 Infant Car Seat, the Cortina Stroller works as a travel system ...
    www.chiccousa.com/gear/travel-systems/cortina-30lb-systems/travel-systems-30-midori.aspx · Cached page
  • Sep 19, 2011 | Chicco Cortina KeyFit 30 Travel System...
    To start with my power steering pump was making a little noise and also had bubbles in the resevoir so i put a new power steering pump on it.not a rebuilt one. when i started it up i still have the bubbles...
    Section 11-00: Steering System-Service 1999 Taurus, Sable Workshop Manual SERVICE PROCEDURES Purging Power Steering System of Air NOTE: If the air is not purged from the power steering system correctly, a second customer concern or pump failure could result. This condition can only occur on pre-delivery vehicles with evidence of aerated fluid or vehicles that have had steering component repair.
    A whine noise heard from the power steering pump may be caused by air in the system. The following procedure must be performed whenever any of the following are performed:
    • All power steering noise complaints with evidence of aerated fluid on pre-delivery vehicles only, prior to any component repair.
    • After any power steering system component (for example, gear or hose) has been replaced and the noise is heard.
    Fluid Level Top-Off Procedure
    1. Check and fill pump reservoir to dipstick full cold or remote reservoir center mark.
    1. Disable ignition by removing Fuse 10 in the fuse junction panel.
    1. Crank engine 30 seconds, check fluid level and add if required.
    1. NOTE: Do not hold steering wheel on stops.
      Crank engine 30 seconds while cycling the steering wheel lock to lock.
    1. Check fluid level and add fluid if required.
    Air Purge with Vacuum External Source Procedure - 3.0L (2V) Engine, Flex Fuel and 3.4L SHO Engine
    1. Tightly insert the rubber stopper of the air evacuator assembly into pump reservoir.
    1. Reinstall Fuse 10 used to disable ignition and start vehicle.
    1. Apply 20-25 in-Hg (85-88 kPa) maximum vacuum for minimum of three minutes at idle; maintain maximum vacuum with vacuum source.
    1. Release vacuum and remove vacuum source.
    1. Add fluid to full warm or reservoir center mark.
    1. Reinstall vacuum source and apply 20-25 in-Hg (85-88 kPa) vacuum.
      Cycle steering wheel from lock to lock every 30 seconds for approximately 5 minutes.
    1. Shut engine off, release vacuum and remove vacuum source.
    1. Add Motorcraft MERCON Multi-Purpose (ATF) Transmission Fluid if necessary and install dipstick or reservoir cap.
      Start engine and cycle steering wheel from lock to lock every 30 seconds for approximately 5 minutes.
    1. Check for oil leaks at all connections.
    1. In severe cases it may be necessary to repeat air purge with vacuum source procedure.
    Air Purge with Vacuum External Source Procedure - 3.0L (2V) and 3.0L (4V)
    1. Add Motorcraft MERCON® Multi-purpose (ATF) Transmission Fluid XT-2-QDX or MERCON® equivalent to approximately 2.5 cm (1 in) (make a mark) above the top of the supply line.
    1. Tightly insert the rubber stopper of the air evacuator assembly into the pump reservoir.
    1. Apply 85-88 kPa (20-25 in-Hg) maximum vacuum for a minimum of three minutes.
    1. Add Motorcraft MERCON® Multi-purpose (ATF) Transmission Fluid XT-2-QDX or MERCON® equivalent until the level is at the marked point.
    1. Repeat Steps 3 and 4 until the fluid level stabilizes.
    1. Check reservoir level and add Motorcraft MERCON® Multi-purpose (ATF) Transmission Fluid XT-2-QDX or MERCON® equivalent to the FULL WARM (MAX) mark.
    1. Install the number 10 fuse in the fuse junction panel. Start the engine.
    1. NOTE: The front wheels must be off the floor during lock-to-lock rotation of the steering wheel.
      NOTE: Do not hold the steering wheel on stops.
      Reinstall the vacuum source and apply 85-88 kPa (20-25 in-Hg) maximum vacuum and cycle the steering wheel from lock-to-lock every thirty seconds for a minimum of 5 minutes.
    1. Shut the engine off, release the vacuum and remove the vacuum source.
    1. Add Motorcraft MERCON® Multi-purpose (ATF) Transmission Fluid XT-2-QDX or MERCON® equivalent to the FULL WARM (MAX) level. Install the dipstick or reservoir cap.
    1. NOTE: Do not hold the steering wheel on stops.
      NOTE: In severe cases, it may be necessary to repeat air purge with vacuum source procedure.
      Start the engine and cycle the steering wheel from lock-to-lock every thirty seconds for approximately five minutes.
    1. Lower the vehicle front end.
    Jul 24, 2011 | 1999 Ford Taurus
    There is no local channel,cable only international..i lost my manual,
    Hello
    Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
    If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
    skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
    the TV automatically scans through all available channels, memorizing the active ones and
    skipping over blank ones or channels with weak signals. This means you scan using the
    CHANNEL +/- buttons), you will receive only clear active channels.
    Press the MENU button
    ?† To AUTO TUNER SETUP
    ?® To operate
    ?® To choose CABLE or AIR
    Press the OK button to start
    Initial Setup
    Auto Tuner Setup
    Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
    message PROGRAMMING OVER! appears onscreen.
    Channel Summary
    Channel summary allows you to customize the line-up of channels received by your TV. You
    can add or delete channels from the line-up or prevent any unauthorized viewers from watching
    any or all 181 channels.
    ?† To CHANNEL SUMMARY
    ?® To operate
    The Channel summary screen will now be displayed with
    the channels set to scan marked with an "?". You can delete
    channels from the scan by removing the "?". If any channels
    were missed during auto tuner setup and you wish to add
    them, you may by placing an "?" next to the channel number.
    ?† ?® To the SCAN column
    Press the OK button to include or delete from scan
    Press the MENU button when finished
    You can block access to a channel by activating the channel lock.
    ?® To operate
    ?† ?® To the Lock Column ( )
    Press the ZERO button to lock or unlock that channel
    AUTO TUNER SETUP
    CABLE
    If you wants any codes, contact me through Fixya. Ok
    I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
    Nov 08, 2010 | JVC AV-32S575 32" TV
    I have a Husqvarna trimmer model # 128LD.I want to get a tiller attachment.Can you give me the model I need for my model?
    If you have the 128LD from Lowe's, Tractor Supply or Sears you can use TrimmerPlus attachments, any MTD manufactured attachments should work.
    http://www.trimmerplus.com
    May 26, 2010 | Husqvarna Garden
    How can i patch a hole on fuel tank
    put an o-ring on a screw a little bigger than the hole and screw it down till the oring is compressed. This has worked for me, hope it helps you
    Dec 18, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Troy Bilt Tb70ss Gas Trimmer Logo
    228 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
