Question about ViewSonic VX2235WM Monitor
Hi, my Viewsonic monitor was working perfectly fine (and is relatively new) until I went on vacation for 3 weeks. I came back and it would not turn on. I tried plugging/unplugging it and turning it on/off several times but it won't turn on at all. I have also tried using my remote to turn it on (I have been using my monitor as a television). Its model is N2750w. Is there anything I can do to fix it? Thanks.
  • 11,361 Answers
N2750 is more than 3 years old, so more likely the DC filter caps are already bad with bulging tops.
See pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N2750W_MARCH%202005/
Very common problem with LCD TV/Monitors that are more than 2 years old as you can see in my albums.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
My company has 2 viewsonic vx2235wm monitors that have recently died on us. First my co-workers monitor went black and the blue light turned orange. Then we turned it off and back on it would stay on for...
More than likely this is a driver problem. Many people are having this issue with the new driver that has been made available for this monitor. I have two of these monitors in a dual configuration and had the same problem. You will need to download the old driver or just delete the new one that downloaded and it should fix itself.
Good Luck,
Rob Mixon
Jun 05, 2009 | ViewSonic VX2235wm LCD Monitor
Testing IM-6 Water inlet valve
check water valve or icemaker
Apr 06, 2009 | GE Refrigerators
Screen went black
Swap monitor connections to determine if one of the monitors is not working.
If one is not working you probably have an internal problem. If power led responds to the off-on button but no picture is seen, the inverter has likely blown a fuse. Replace the fuse and resolder the leads on all 6 inverter transformers or the fuse might blow again.
Monitor Mike
Mar 27, 2009 | ViewSonic VP201s 20.1" LCD Monitor
Viewsonic 19
Hi...there,
But of course...it's can. Asked him if the LCD Monitor got any power (a green light on) If it has, switch cables, if it have a DVI connection used that cable and see if it work. Still had a problems...Then the backlight is burnt out. Have a nice day!
Sep 07, 2008 | ViewSonic VX924 19" LCD Monitor
ViewSonic VX2235WM Monitor Logo
93 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
