Question about Vulcan EF3 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
I was cleaning My Fryer and the Pilot went off...I turned and pushed in the pilot Knob and lit the pilot as soon as I release the knob the pilot turns off Iam  I missing a step..Dont know what to do after previous steps..
  • noel69 Dec 06, 2008
  • antica Dec 23, 2008
    the thermo pilot when off while i was working. i changed the thermo pilot, high limit valve, and the gas valve, and it still doesn't work. i only receive gas when i push the pilot button. the thermo pilot gets hot, but as soon as i release the pilot button, the gas will cut off.
You have to hold the knob in after pilot is lit for at least one minute
Posted on Aug 04, 2008
I have a vulcan fryer and i can light the pilot then i turned on the flames it came on then went out and would not come back on the pilot stayed lit.
Sounds like thermostat is bad... Vulcan also recommends on replacing the high limit as well.
If you have further questions, call Vulcan directly and they will direct you to a dealer that sells their parts... Their number is 502-778-2791. If I can help in any other way, call me at 888-542-5959, Restaurant Equipment Outlet, Cincinnati, OH and our website is www.restaurantequipmentinc.com
Aug 13, 2011 | Vulcan EF3 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Pilot light will not stay lit as soon as you let off the gas valVE arm it will go out. vulcan model TK 65
1. Check to make sure you have continuity across the high limit terminals.( you can use a jumper wire for testing) Unit operates on about 1/2 of 1 volt so no worry of a shock. 2. Check to make sure your pilot generator is producing over 500 millivolts. Make sure the pilot orifice is clean and that you have a nice sharp pilot flame heating the pilot generator.
Tom
Aug 03, 2010 | Imperial IFS40 Deep Fryer
Pilot won't lite. fryer is 6 months old. Did get pilot to lite once and as soon as we turned thermostat pilot went out.
When you turned on the thermostat you required more millivolts from the system and it failed. Low millivolts. That would tell you the pilot generator needs replacing. Make sure you have a good pilot flame hitting the pilot generator.
Tom
Jul 07, 2010 | Vulcan EF3 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
Vulcan fryer gas control knob will not turn
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Nov 16, 2008 | Vulcan EF3 Deep Fryer
VULCAN EF3 PILOT, ON, OFF, KNOB NOT TURNING
That knob is a pilot safty valve it is not your problem. Your problem is the m/v signal generator. This is either a thermocouple or a thermopile depending on the setup of your model. Look for a small copper line coming from the pilot area going to the pilot safty valve that is the tcouple or tpile. Replace this and I am sure you will be good to go.
Hope this helps Ya
please rate me.
Jul 19, 2008 | Vulcan EF3 Deep Fryer
Vulcan EF3 Deep Fryer Logo
925 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
