Question about Kenmore Microwave Ovens
Our ignitor is stuck on on our Kenmore 790 range. It's the large "power burner" in the front. How can we stop the clicking?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Posted on Jan 04, 2011
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
Aug 07, 2014 | Kenmore Microwave Ovens
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
Two ignitors are stuck and will not stop sparking
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
May 02, 2011 | Microwave Ovens
My Jen-Air Gas cook top ignitors keep clicking when one or all 4 are lit can this be stopped
heatman101
Apr 16, 2011 | Microwave Ovens
I have a kenmore elite range model number 790 46809 991 and the burner on both the left and right are acting up. They both show that a burner is on on the control panel (not surface indicator) and the...
Hello gralexander,
The problem you are experencing is with you control switches. The cheapest place i can find the switch is from searsparts direct. Here is a link to the webpage http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046809991/0583/0124160/P0050380/00001?blt=06&prst=0&shdMod=79046809991
You will see a diagram in the top left side of the page use it to locate the switches that are bad and order them from sears. You may also need the burners to check them you need a continutity tester.
1. Remove the burner from the socket
2. Take your test and touch one probe to each side of the burner.
3. If you have continunity then the burners are good
4. If not you will have to order burners as well.
Changing the switches:
1. Unplug the range
2. Remove the back panel where the switches are.
3. Remove the knob from the front
4. Remove the screws from the switch you are replacing (Due one at a time)
5. Move the wires from the switch to the corresponding terminal on the new switch
6. Replace the switch and screw in place
7. Do the other switch
8. Reinstall the cover on the back of the unit
9. Plug in and try
Doing all of the above steps should fix the problem that you are having. Please make sure that you install L1 to L1 and L2 to L2 on the new switch other wise you will cross wire it and the rest of the switches will short and need to be replaced.
Thank you for choosing FixYa.com. If you have any other questions please post back to this thread and I will do my best to help you with your Range problem
Justin
Mar 10, 2011 | Kenmore 63252 Microwave Oven
Whirlpool cooktop model # sc8900exb1 ---ignitor is activated with cooktop burners turned off
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 15, 2010 | Microwave Ovens
The pilot and burners will not stay lit and,the ignitor keeps trying to light.its a 4 burner flat top.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
85 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
