Question about Canon imageCLASS MF6550 Monochrome Laser Copier
Multiple fax copies only 1 or 2 get through
We have a brand new canon imageclass mf6550, everytime we send fax with multiple copies, reciever only get 1 or 2 of 5 copies sent.
    Sergeant:
  • 329 Answers
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
Posted on Jul 09, 2008
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Is there a way to find out the total copy count for the printer?
You can get the copy count for the MF6550 by using the following procedure:
- Press Additional Functions
- Press 2
- Press 8
- Press Additional Functions again.
- Scroll down through the options. There will be an option for Counter -- select it and the copy count will be displayed on the screen.
For page count and configuration page instructions on other copiers, printers, and fax machines, visit the How to Print Configuration Pages website.
Jun 15, 2011 | Canon imageCLASS MF6550 Monochrome Laser...
Blank copies on a canon mf6550. already tried a different drum unit
the copies are blank the laser beam does not reach the drum, the scan operation was not performed, check the lever that lock the laser unit, if blocked release it.
Oct 28, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
CANON MF6550 COPIES ARE COMING OUT BLANK
The Canon MF6000 series devices have a bad problem of the scanner shutter not opening. It will cause blank copies. Replace or remove shutter. Usually done by technician. Call Canon, you may get it fixed for free.
May 22, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Canon MF6530, intermittent blank copies using ADF
Its an laser shuter problems, you can say its factory error, if its under varanty call service to fix it
Feb 11, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Duplexing
Someone has changed the settings on the unit. If you go into Additional Functions press set on Common Settings scroll to Paper feed switch and set it for Speed Priority not Print Side for each category. The only other thing that would cause this is that each individual setting was set for 2-sided in which case you would want to check Additional Functions and each one Copy Settings, Printer Settings and Fax settings.
Nov 24, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Canon imageclass mf6550
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
May 06, 2008 | Canon imageCLASS® MF6550 Laser Printer
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
Apr 18, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Canon imageCLASS MF6550 Monochrome Laser Copier Logo
104 people viewed this question
old marine
old marine
