My Maytag washer said suds then f 35. what does it mean do I need it repair?
  • Washing Mach... Master
  • 8,220 Answers
Some F-35 notes:
F35: ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
Item 20
$86:
Keep in mind if too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
Posted on Jan 04, 2011
  • Dan Webster
    Dan Webster Jan 04, 2011
    various components:
Not sub but it displays suds on my 9000 maytag wqsher
My Kenmore washer does that too, it means there is too much suds in the tub so the machine will go thru a rinse type cycle to remove the excess suds. It should then go back to normal washing.
Jan 15, 2015 | Maytag Washing Machines
Tip
Maytag F-35 (suds) error code resolved
Maytag Washer F-35 error code ( SUDS) >> Look for a faulty Pressure switch or bad pressure hose.... Problem solved !
on Aug 04, 2010 | Washing Machines
I keep getting error codes on washer and will not continue the cycle
That code in most cases means you have a bad pressure switch. It is generally $99.00 (approx) for the cost of the part.
May 11, 2012 | Maytag Performance MHWE500V Front Load...
Gives code f02 and sud
The F2 error codes means LONG DRAIN TIME and the suds code the washer detected water in tub after normal alloted drain time...so basically the F2&SUDS means the same thing. A lot of times when it does not drain fast enough,its caused by a blocked filter on the pump being biult up with debris. This tip i wrote will show ya how to clean the pump filter.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
F 35 comes up how do i fix it. then suds
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Jul 22, 2011 | Maytag Performance MHWE500V Front Load...
The washer showed a code 5d what does this mean
5D actually means suds, make sure you aren't using normal detergant as these units require 'HE or High Efficiency' detergant that doesn't suds much. Try runing a load with not clothes and just put in a cup of white vinegar to remove all the suds in the machine and see if goes through spin with no suds in. If not and you still get an error you will need to replace the pressure switch because it thinks there is water or suds in the machine it's not removing.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 10, 2011 | Maytag EPICz 3.7 cu. ft. Washer
What does the code suds mean on my maytag neptune washer
sud's ( like to much soap ) this causes the machine to shut down . mix some downey of fabric softner in a quart of water . pour it in tank . let set over night . and try again . fabric softner will get rid of suds or at least reduce them . it will probably work .. mm
Dec 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
SUDs followed by F 35 error code
its junk and it should be a crime t sell to hard working people never did work good and it needs to go back across the ocean junk yard won even take it
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load whasher MAH8700AWW Error/Information code OE is showing and does not show up in owners manual. What does this mean
my maytag mag8700 (4 yrs old) has begun to shake so bad itt walks 4" to the wall. it did not do this before. i regularly get SUDS code. i did run afresh through 3x's. 2 weeks later i have SUDS code again HEPL!
Mar 23, 2008 | Washing Machines
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
