Question about Garden
A section of line has been cut by a whipper-snipper. What is the best way to fix this? Do I need a completely new full length of line?
    Problem Solver:
  • 4 Answers
If you are referring to your gas line, the safest way is to insert a plastic or metal tube (or even a fuel filter) in this spot with a worm gear clamp on each side.
Posted on Jan 05, 2011
I am looking for a new battery for our whipper snipper 18V0135CH, where can I purchase one
from the manufacturer or manufacturer service agent
from a battery shop
Jan 23, 2017 | whipper snipper Garden
How to remove Rockwell whipper snipper cutting hub
cutting hubs on trimmers are held on by a left hand thread nut
turn the hub center / nut in the right direction ( as if doing it up)and it will come undone
Jan 09, 2016 | whipper snipper Garden
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
My whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Mar 01, 2010 | Garden
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Oct 18, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
