Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Faucet is loose. How do I tighten it up? - Blanco Classic Single Handle Faucet with Pull-Out Spray ....
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have to go under the sink and tighten the bolts, you may require special tools to tighten..or contact a handyman
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
How do I tighten a loose kitchen faucet
buy a basin wrench, slip it on the large nut on each side of the faucet under the cabinet and tighten. The wrench head flips from one side to the other for tightening or loosening.
Nov 03, 2015 | Plumbing
How to tighten loose handles on the 2 handle Delta Vessona kitchen faucet model #21925LF
usually have a setscrew in them!! mine are allen heads very small
Feb 11, 2015 | Delta Plumbing
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Delta single handle pull-out sprayer loose from base. How to tighten it?
Pull out sprayer has a plastic nut to tighten under countertop. You should be able to reach underneath and hold the top while tighting the bottom.
It designed to be tighten by hand to avoid damaging.
May 19, 2010 | Delta Faucet 470-DST Signature Diamond...
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
406 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
