Question about Craftsman 34-83899 Triple Tap Power Outlet Cord Reel
As of today my craftsman cord reel no longer retracts. It made more noise than usual when pulling cord out, then only retracted about half the cord. Any one else have this problem, and is it repairable by yours truly. Thanks, Bill
sleprocks
  • 147 Answers
SOURCE: starter rope pulled out and wont retract on
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Posted on Oct 22, 2009
backwoodsctr
  • 169 Answers
SOURCE: craftsman 316794990 leaf blower. I have a problem
Lakeviewpower dot com here is a link to my website. Call me on price and avilibility. Part number mc 9228 320602. Mtd model number 41ar322g799 1 972 475 9946
Posted on Nov 21, 2009
  • 8 Answers
SOURCE: pull cord won't retract when housing asseembly is
housing is pressing on recoil sprocket,,,,shim with washers to get clearence. Also check to see if recoil sprocket is seated all the way down aginst the stop on the crankshaft.
Posted on Apr 27, 2010
riceski
  • 1851 Answers
SOURCE: hedge trimmer broken
Any local repair shop will do this for you - if you're looking for free repair -then please - look at the local sears store to direct you as they have the locations there.
Thanks
Gary @ Fix Ya
Posted on Jun 30, 2010
  • 3 Answers
SOURCE: How can I get my pull cord to retract on Craftsman
HORSE POWER NOT STARED
Posted on Jul 10, 2011
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
Cord won't retract on exectrical cord reel
The most common cause is the the cord has been extended past its limits (fully extended) and can't be pulled any further to pull the latching mechanism far enough to release and allor the winder to do its think. (I used to manually force it to move further by using a screwdriver. Pushed the coil a bit further over (as if more cord was being extracted), just to the point where the latch could release.
There's a troubleshooting guide on the Reelcraft website. Perhaps it can help.
Reelcraft Reel Support Hose will not retract
Jul 28, 2014 | Reelcraft Retractable Triple Tap Electric...
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Kenmore 116.26212602 cord won't retract completely
This is a common Kenmore problem. The cord may have kinked inside the cord reel, You can remove the top by taking the screws out some are hidden under the switch. If the cord gets too close to the edge of the reel it can bind. Do be careful as the spring in the cord reel can jump out and it hurts. I would take it to a dealer.
Jan 31, 2014 | Vacuums
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Jul 26, 2009 | Black & Decker Irons
Electric cord will not retract
I found the solution from another web site. Removed the reel coil, cleaned it of lint, etc. replaced it and it is now working. Thank you for your relpy
Jun 26, 2008 | Vacuums
Craftsman 34-83899 Triple Tap Power Outlet Cord Reel Logo
277 people viewed this question
Top Craftsman Electrical Supplies Experts
wadingriver
wadingriver
ray gallant
Steve Pack
Steve Pack
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
