Question about Sharp R-1850A Convection/Microwave Oven
I need a new door or glass for the door and can't find one. Any ideas?
  • 731 Answers
I have a kitchenaid microwave handle to replace
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 18, 2009 | GE Advantium SCA1000H Convection /...
How do i replace the door handle.
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have questions about this repair, please let me know. I hope this helps you.
Aug 10, 2009 | Microwave Ovens
How to replace door handle?
The door handle can easily be replaced. This is a common problem with microwave oven doors.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 30, 2009 | Microwave Ovens
Can i replace a broken door handle?
Yes. This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Handle replacement on GE JVM 1860SD
Jul 01, 2009 | Microwave Ovens
Need to replace the handle I have the part but how do i desassemble the door properly
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jun 03, 2009 | Microwave Ovens
A broken handle on door&how to fix it
If you have questions, or need assistance ordering parts, please let me know. Post back with your Model Number if you need parts assistance. I hope you find this information helpful.
May 13, 2009 | GE Microwave Ovens
Need microwave glass door replacement
http://www.mdappliance.com/WPL-W10206726.html
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=1946925
Here are 2 sites that have it. The second site has in stock in alabama ready to ship.
Good Luck and Please Rate FixYa!
Feb 25, 2009 | Microwave Ovens
Sharp R-1850A Convection/Microwave Oven Logo
56 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
